Timing Set re-usable??? - Chevelle Tech
  • 1 Post By jeff swisher
post #1 of 7 (permalink) Old Nov 26th, 17, 12:34 PM Thread Starter
Would you guys reuse this Billet Timing set with the Torrington Roller Bearing, looks like previous builder over torqued cam bolts (bolt holes are marred up) and I have a suspicion that it was in the wash, however when I apply pressure on the Torrington bearing and rotate, it seems to rotate fine.
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #2 of 7 (permalink) Old Nov 26th, 17, 7:30 PM
jeff
Re: Timing Set re-usable???
Looks cosmetic to me and looks like lock washers are possibly what ate it.
If it fits good and is smooth I would run it in my own personal stuff.
RichardB likes this.
jeff swisher is online now
post #3 of 7 (permalink) Old Nov 26th, 17, 7:44 PM
run it!
mark_follweiler is offline
post #4 of 7 (permalink) Old Nov 26th, 17, 7:51 PM
I would have no problem using that just so the bearing is fine.
64 Chevelle 496
StevenS is offline
post #5 of 7 (permalink) Old Nov 27th, 17, 2:38 PM
Lang
You did not say what engine it was for but these are available https://www.summitracing.com/parts/m...0aApCkEALw_wcB
langss is offline
post #6 of 7 (permalink) Old Nov 27th, 17, 5:52 PM Thread Starter
Not running lock washers, I'm using ARP bolts with a shoulder washer, to clear the cam button
-Super T10 2.64
-Dana 60 3.54 Posi
post #7 of 7 (permalink) Old Nov 27th, 17, 5:53 PM Thread Starter
Its a BBC 427, I can't run that due to cam button and not enough clearance
-Super T10 2.64
-Dana 60 3.54 Posi
This Thread is more than 911 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
