Do I need a telescoping steering shaft for drag car that twist - Chevelle Tech
 10Likes
post #1 of 21 (permalink) Old Nov 11th, 17, 3:52 PM Thread Starter
Rob
Question Do I need a telescoping steering shaft for drag car that twist
Do I really need a telescoping steering shaft if my 70 Chevelle twist on launch? is there much movement between the column and steering box
Im changing the shaft out to a smaller style for clearance like the Borgeson Steering Shafts,http://bionicengineering.net/media/IMG_0904.JPG
or pick below
does anybody make a smaller version than the Borgeson one
Rob
ID:	494386   Click image for larger version
Name:	Chevelle tire test 025 (Medium).JPG
ID:	494394   Click image for larger version
71350SS likes this.
Plan B Kill It With Fire
Strip Poker 388 is offline
post #2 of 21 (permalink) Old Nov 11th, 17, 4:17 PM
Re: Do I need a telescoping steering shaft for drag car that twist
The car shouldn't be twisting. That should only be suspension movement. The body should move with the frame.
Steve R likes this.
Ray
bracketchev1221 is offline
post #3 of 21 (permalink) Old Nov 11th, 17, 4:29 PM
Allen
From the launch photo, I'd think a drag specific rear ARB might be helpful.
Blown1932 is online now
post #4 of 21 (permalink) Old Nov 11th, 17, 4:32 PM Thread Starter
Rob
when it launch's once its up in the air it looks like the front end/fire wall froward is twisting,
just wondering if its sliding in the stock steering shafts,
or not enough movement to change out to the above w/ no slip joint
Rob
post #5 of 21 (permalink) Old Nov 11th, 17, 5:41 PM
Look at your bumper line compared to the pavement, the right rear tire is buried in the fender well, left tire is almost out. You need an ARB not a steering shaft.
mr 4 speed and 90lxracer like this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #6 of 21 (permalink) Old Nov 11th, 17, 9:22 PM
Needs an ARB, have a look at these bolt on style
HRpartsNstuff "Your WWW performance parts supplier"
Kevin
The more people I meet the more I love my dog
ss/gn is offline
post #7 of 21 (permalink) Old Nov 11th, 17, 10:32 PM
I installed an ARB and dropped 2 tenths on my 60 foot.
cozmacozmy likes this.
Mike 70SS is offline
post #8 of 21 (permalink) Old Nov 12th, 17, 6:11 AM
Durand
Listen to the ARB recommendations.
I'm glad I did.
My 65' used to twist and list out of the hole like a sailboat on launch, worse than yours does.
After installing the ARB it now launches flat and square like a brick.
LaVelle is offline
post #9 of 21 (permalink) Old Nov 13th, 17, 12:25 PM Thread Starter
Rob
Question Re: Do I need a telescoping steering shaft for drag car that twist
Thanks for the advice but It has a ARB.
The Chassis Works arb was sold to me as a ARB,told them what was to the car and a video from the front of the launch. $519 latter, I send them the video view from gopro of rearend and arb twisting, they then said it was a street ARB.
Like Blown1932 I need a (drag specific rear ARB) after headers (steering shaft) I've got TRZ building a 9in w/ a real ARB.
Back to the steering shaft
Rob
https://www.cachassisworks.com/p-135...able-1-18.aspx
old motor
https://youtu.be/F95aPKlPP14
ID:	494770   Click image for larger version
post #10 of 21 (permalink) Old Nov 13th, 17, 1:12 PM
If the front end is moving that much there is bigger issues. I was going 9.30's with stock steering parts and no front bracing with 1.28 60' times carrying the wheels every pass.
John 67 SS likes this.
Ray
post #11 of 21 (permalink) Old Nov 13th, 17, 3:11 PM
Nice looking ARB, but it looks like it is not controlling the body roll, the bar must be flexing, or allowing flex, is what my conclusion would be. My last bolt on ARB was bent 3/4" out of square when I took it off, but was still launching flat, no roll.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #12 of 21 (permalink) Old Nov 13th, 17, 4:10 PM
Larry
Hi , you could move those brackets that hold the arb to the diff housing further apart , out to where the arb just starts to bend and go forward , that will get the most stiffness out of what you got
Cowfarmer is offline
post #13 of 21 (permalink) Old Nov 13th, 17, 6:18 PM Thread Starter
Rob
I figure I need some bracing tie the frame together better,box in, etc 6pt roll bar in it now, But the car is 3998,it weights 2158 just on the front, ive run some preload and it didn't help, just need change it out w/ new rearend.
Rob
post #14 of 21 (permalink) Old Nov 14th, 17, 8:00 AM
Here is how the car was with the stock steering, roll cage ended at the dashboard, and stock motor mounts.
Ray
post #15 of 21 (permalink) Old Nov 14th, 17, 9:32 AM
Jarad
What does this car ET? Good looking hotrod.
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
This Thread is more than 862 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
