Shear plate vs 4 hole spacer, same thing? - Chevelle Tech
post #1 of 4 (permalink) Old Nov 9th, 17, 1:18 PM Thread Starter
Whats the difference?
3495,NA,Driven to the track,UD Harold hydraulic roller
wawa 89E0 /112
1.27
[email protected]
[email protected]
Vp 109
1.352
3.797
[email protected]
7.682
[email protected]
J.MARTZ is offline
post #2 of 4 (permalink) Old Nov 9th, 17, 1:41 PM
Re: Shear plate vs 4 hole spacer, same thing?
One raises the carb up a little bit more? Assuming the spacer is solid...
I'm guessing this is for a dominator? have you thought about having the linkage moved to outside of the carb? Boom.. no need for a shear plate!
90lxracer is offline
post #3 of 4 (permalink) Old Nov 9th, 17, 1:51 PM
Picture please.
WHT/73 is offline
post #4 of 4 (permalink) Old Nov 9th, 17, 2:29 PM
I THINK what you are asking about is an anti reversion plate for under the carb. Like the Reher-Morrison setup?? No they aren't quite the same thing. The reversion plate is curved underneath to redirect the gases down, though a 4 hole spacer probably prevents the pulses from hitting the carburetor. Reher-Morrison has one that is 1.5" tall over all that has the spacer blended to the plenum and the 1/2" reversion plate is blended to the 1" spacer.
Anti-Reversion Plates | Reher Morrison Racing Engines
https://www.summitracing.com/parts/wsn-525215
bracketchev1221 is offline
This Thread is more than 738 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
