Any experience with gen viii/Vortec 8.0 blocks? - Chevelle Tech
post #1 of 12 (permalink) Old Nov 8th, 17, 11:02 AM Thread Starter
GMPP Vortec 8.0 engine block...anyone know what kind of bores these modern tall deck bbc blocks take?
Sent from my SM-J700P using Tapatalk
DeucesAllin is offline
post #2 of 12 (permalink) Old Nov 8th, 17, 11:11 AM
Re: Any experience with gen viii/Vortec 8.0 blocks?
You don't hear/see much about them.
Don't know why but I'm sure we'll find out!
WHT/73 is offline
post #3 of 12 (permalink) Old Nov 8th, 17, 11:12 AM Thread Starter
Cheaper than machining a seasoned block, by my math...
post #4 of 12 (permalink) Old Nov 8th, 17, 11:17 AM
Oh, I thought it was the LS/496 deal.
My bad.
WHT/73 is offline
post #5 of 12 (permalink) Old Nov 8th, 17, 12:43 PM
Tall deck does not use a standard intake or distributor. May also have header fitment problems due to the added height.
63 Nova wagon
Philip is offline
post #6 of 12 (permalink) Old Nov 8th, 17, 4:24 PM
There's a guy around here or on the Corvette site that's done a ton of custom work on intake, bracketry, the works getting one into his ride. Great fab skills and an impressive job, haven't seen an update in awhile...
Gary Adrian
Busted Knuckles is offline
post #7 of 12 (permalink) Old Nov 8th, 17, 5:09 PM
I agree with others. That is the O.E.M. engine in the 02--03 ( ??? ) Chevy Suburban. A buddy of mine has one. I would guess is like the old 427 TRUCK ( Tall Deck)engine.
A lot of the standard B. Block items, Do not work on this block.
Robinls5 is offline
post #8 of 12 (permalink) Old Nov 8th, 17, 9:04 PM Thread Starter
No. The Gen 7 came in early 2000s Suburbans/Avalanch 2500s. Thats the 8.1l oddball.
The Gen 8 is a modern design that uses LS style coil near plug, with modern BBC architecture, mark iv-mark vi heads, as well as a distributor hole and a fuel pump provision.
4.270"x4.250" (opposed to the 8.1L's 28x4.375)
post #9 of 12 (permalink) Old Nov 9th, 17, 9:14 AM
Looks like a tall deck Gen 6 to me, conventional type heads, non-siamesed cylinders, etc. It gets cubes from 4.270" bore and a stroker (4.25") crank. Built as a crate engine for LP/CNG. I can't see the advantage over a tall deck Gen 6 with a stroker crank. With the right fab work, ANY engine can run cam and crank sensors and coil near plug, I've seen more than one Gen 6 with that setup.
Gary Adrian
post #10 of 12 (permalink) Old Nov 9th, 17, 12:52 PM
Why not use an L21 if you want the CNP set up?
63 Nova wagon
Philip is offline
post #11 of 12 (permalink) Old Nov 9th, 17, 11:26 PM
The marine guys seem to have a handle on their use of the 8.0's - and have high performance parts in use - FWIW.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #12 of 12 (permalink) Old Nov 10th, 17, 12:43 AM
Marine parts are not cheap
Philip is offline
This Thread is more than 737 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
