Anybody else running 5/16 fuel line to 496? - Chevelle Tech
 4Likes
post #1 of 36 (permalink) Old Sep 5th, 17, 6:54 PM Thread Starter
Rob
Never checked my fuel line size all these years, today I was underneath the rear end doing some maintenance and figured I'd check fuel line diameter seeing it was staring me in the face, well its only a 5/16th line!!!
thought it was 3/8".....anybody else running the same size line going to 496? Car runs good so I don't really want to change it if not necessary!
Fuel pump is Holley mechanical 12-454-11, 110 gph
Thanks,Rob
68 Beaumont 3900#
496 ,10.5 comp, Brodix RR 270
Bullet Custom HR 234/[email protected]
Rpm Airgap, Holly 950 HP Street
1 3/4 Flowtech Headers
TH400, Freakshow 9.5 3500 stall, 3.55 12 bolt
Best 60ft 1.62
Best 1/8 [email protected]
Best 1/4 [email protected]
68Beau is offline
post #2 of 36 (permalink) Old Sep 5th, 17, 7:04 PM
Re: Anybody else running 5/16 fuel line to 496?
I am surprized that size line has worked so well. Your car runs good.
fenns70 likes this.
64 Chevelle 496
StevenS is offline
post #3 of 36 (permalink) Old Sep 5th, 17, 7:05 PM
bottom 11s at 120 on a 5/16 line. Yikes. Got pistons?
post #4 of 36 (permalink) Old Sep 5th, 17, 7:09 PM
5/16'6...why?!
1969 Nova SS 350
EFI 407 / TKO600 / 4.11
11.41 at 121 MPH
L48M20 is offline
post #5 of 36 (permalink) Old Sep 5th, 17, 7:16 PM Thread Starter
Rob
Originally Posted by Tom Mobley View Post
boittom 11s at 120 on a 5/16 line. Yikes. Got pistons?
I checked plugs ,no signs of detonation, not running lean either! only spin to 6000 if that makes a difference.
68 Beaumont 3900#
Best 60ft 1.62
68Beau is offline
post #6 of 36 (permalink) Old Sep 5th, 17, 7:21 PM Thread Starter
Rob
Ok, by the sounds of it so far I think I better do a fuel line up grade...might be pushing my luck!
Thanks, Rob
68 Beaumont 3900#
Best 60ft 1.62
68Beau is offline
post #7 of 36 (permalink) Old Sep 5th, 17, 7:24 PM
You are running on the edge
64 Chevelle 496
StevenS is offline
post #8 of 36 (permalink) Old Sep 5th, 17, 7:25 PM Thread Starter
Rob
Can anybody recommend a good fuel line kit to install, looks like its not an easy job!
68 Beaumont 3900#
Best 60ft 1.62
68Beau is offline
post #9 of 36 (permalink) Old Sep 5th, 17, 7:31 PM
AKA Zombietroll
It is easy. Just remove the old one then bend the new line to match as best you can. Then install it.
zombie1969 is offline
post #10 of 36 (permalink) Old Sep 5th, 17, 7:49 PM Thread Starter
Rob
What's the minimum size you guys would recommend!
68 Beaumont 3900#
Best 60ft 1.62
68Beau is offline
post #11 of 36 (permalink) Old Sep 5th, 17, 7:51 PM
Kerry
1/2". Put a RobbMc pick up in as well, unless you have a sumped tank.
pockets is offline
post #12 of 36 (permalink) Old Sep 5th, 17, 8:28 PM
MARK
Its not easy
Wolfplace likes this.
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #13 of 36 (permalink) Old Sep 5th, 17, 8:37 PM
Gary
put a fuel pressure guage on it and make a pass. it might scare you
Todd69SS likes this.
gnicholson is offline
post #14 of 36 (permalink) Old Sep 5th, 17, 8:46 PM
I have heard that you can not put a one piece line in without jacking the body, but dont have personal experience. If out do some searching in the forums I bet you will find a lot.
artmalibu is offline
post #15 of 36 (permalink) Old Sep 5th, 17, 9:31 PM
Jason
5/16" fuel line, Holley Blue pump, Fram 90 GPH fuel filter. 10.3:1 383 SBC. Started having fuel supply/pressure issues in the 1/8 th mile at around 450 HP. Mid 7's at 93 MPH in 1/8th @ 3610 lbs.
-10 braided line, Mallory Comp. 500 filter and Comp 140 pump worked well at ~730 HP and 6.20's @ 111 MPH in the 1/8 th @ 3650 lbs.
Same line and filter with Magnafuel 500 GPH pump now.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3370 lbs
1.36 - 60', 5.93 @ 116.7 MPH - 1/8th
DragRacer is offline
This Thread is more than 995 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
