1967 Chevelle Fender Bolt - Chevelle Tech
Body Shop Paint & Body Forum
  • 1 Post By 66sc
post #1 of 7 (permalink) Old Jan 4th, 17, 8:25 PM Thread Starter
I'm looking for the lower bolt and J nut that goes on the bottom of the fender? That attaches it to the body.
Any ideas?
twolabs is offline
post #2 of 7 (permalink) Old Jan 4th, 17, 8:53 PM
Re: 1967 Chevelle Fender Bolt
Try here..
https://www.amkproducts.com
1953 Chevy Bel Air 4 door.
1968 Chevy C20 CST Longbed.
1967 Malibu 396 Powerglide.
Cal Malibu is offline
post #3 of 7 (permalink) Old Jan 4th, 17, 10:37 PM
1964-1972 Chevelle Fender Support Braces
Jim T is offline
post #4 of 7 (permalink) Old Jan 5th, 17, 8:30 AM
Dick
I got mine from salvage yard that only has GM vehicles from 1950-1980's. A place where you find the vehicle and remove the part yourself. Think I paid $4.00.
Dick
1967 Chevelle original L34 396 .30 over
390 heads bowl work and ported
CC hydraulic roller cam 218-224 with 510 lift
crane roller tip rockers, port matched RPM manifold,
770 Street Avenger carb, GM HEI Dist. Hedman Elite 1.75 hedders, 2.5" mandrel exhaust with H pipe
3.53 gears with Muncie 20
67AAA is offline
post #5 of 7 (permalink) Old Jan 5th, 17, 11:34 PM
Kev
A bolt that goes vertically up through the fender clamping it to the body? Most are 5/16" body bolts, and the clip nuts, as well as the bolts are as close as the hardware store. The clip nuts aren't the same as GM, but time marches on. A few are bigger and a bit more complicated but more info may be needed.
For those of us w/ loose morals, a troll through the local pick a part will lead to lots of body bolts lying on the ground begging to spend time in your pocket...
Freddy Mercado likes this.
66sc is offline
post #6 of 7 (permalink) Old Jan 5th, 17, 11:51 PM
Bolt 3839741
J nut 3845256
rodent4 is offline
post #7 of 7 (permalink) Old Jan 6th, 17, 8:05 PM Thread Starter
Originally Posted by rodent4 View Post
Bolt 3839741
J nut 3845256
Sweet Thanks
twolabs is offline
This Thread is more than 1243 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
