1964 Full Floor help - Chevelle Tech
Body Shop Paint & Body Forum
  • 1 Post By Kaizen
post #1 of 15 (permalink) Old Feb 16th, 16, 12:33 AM Thread Starter
Question 1964 Full Floor help
I purchased and started installing a full floor for my 64 vert. Where it meets the rockers it fits fine. My problem is the rocker ends of the floor braces. The are a ways away towards the floor (top) and get a little closer on the bottoms, but still don't touch. Has anyone else run into this and what did you do to overcome it? Thanks Jeff
1964 Chevelle SS Convertible
msra4896 is offline
post #2 of 15 (permalink) Old Feb 16th, 16, 9:57 PM Thread Starter
Re: 1964 Full Floor help
Anybody???? Please ????
msra4896 is offline
post #3 of 15 (permalink) Old Feb 16th, 16, 11:38 PM
Gary
Use screws to pull it together or put a jack under it and push it up.
You can't break it if it's broke to start with
saltygog is offline
post #4 of 15 (permalink) Old Feb 17th, 16, 12:31 AM
Rob
On my website I have some stuff on floor pans and the size drill bit and screw to use to pull those pans down, take a few days off and read all you can on it. Click on what is highlighted in red.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
rubadub is offline
post #5 of 15 (permalink) Old Feb 17th, 16, 12:32 AM
I like the screw technique drill spot fill holes across the floor brace
and use self tapping screws with washers and pre tighten the floor to the braces.... after all is massaged and fit start your plug welds.
when there ALL done remove the screws and washers and plug weld there holes to the floor brace . I also have a big cloth sac filled with old tire chains I use to slam and .push down on 75 /90 lb ! c
Wayne
TC # 186
ACES#1556
WayneK is offline
post #6 of 15 (permalink) Old Feb 17th, 16, 8:11 PM Thread Starter
Question Re: 1964 Full Floor help
I better explain further, My problem is with the floor braces at the rocker panels. My floor came with the braces attached.
[URL=http://s1103.photobucket.com/user/nhrasg/media/DSC05705.jpg.html]
msra4896 is offline
post #7 of 15 (permalink) Old Feb 17th, 16, 9:40 PM
looking at you photo I see the front floor brace has the same radius
with the opening against the inside rocker panel.
Your body is not on the frame Rough pull in the rocker and tack weld or screw the floor braces to the inner rocker panel. I would then hand the door and look for body lines and curves of door bottom to rocker.
Wayne
TC # 186
ACES#1556
WayneK is offline
post #8 of 15 (permalink) Old Feb 18th, 16, 12:43 AM
Terrence
but looks like the bottom is touching? if so in my hack garage i'd make a relief cut at the arch and give it a few hammer hits to roll the side a little then weld up the relief cut.
69 Chevelle Convert
Kaizen is offline
post #9 of 15 (permalink) Old Feb 18th, 16, 1:34 AM
mark
Originally the inner rocker would be sandwiched between the floor pan and braces. Then it could be welded to the braces. At the top the outer rocker would weld the floor pan. I will post some great pics I have of this tomorrow. I just got a complete floor pan to install in my 65' 2dr sedan. I ordered the complete floor with braces and inner rockers already installed. But I received it without outer rockers, the vendor who is located in Wentzville, Missouri has no interest in getting m the part I ordered. I have put so much new metal in my car not much remains original Complete trunk pan, wheel tubs, tail pan, trunk drops, 1/4's, new fenders, one piece floor pan. sure glad I do all my own work or I would have a fortune in labor in this thing.
19velle65 is offline
post #10 of 15 (permalink) Old Feb 18th, 16, 9:26 AM
Michael
I've done pretty much the same on my 64, may have some of my floorpan in my photobucket. I didn't have that problem with mine, every thing seemed to line up fine.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #11 of 15 (permalink) Old Feb 18th, 16, 9:56 AM
It's always best to do the floor braces separate from the floor unless you are doing a complete floor with inner and outer rockers. Pulling them in to the inner rocker is going to be next to impossible with them welded to the floor.
BlueSS454 is offline
post #12 of 15 (permalink) Old Feb 18th, 16, 8:24 PM Thread Starter
Thanks everyone, still figuring this out. I'd hate to have to cut the braces and add a piece into every one of them
msra4896 is offline
post #13 of 15 (permalink) Old Feb 18th, 16, 8:47 PM
Terrence
another thought is to bend the bottom worse to make it even and put in some 1/4 inch plate behind it.....between the brace and inner rocker.
msra4896 likes this.
69 Chevelle Convert
Kaizen is offline
post #14 of 15 (permalink) Old Feb 19th, 16, 12:09 AM
mark
some pics from some original floor braces. This is my 65' getting new floors.
ID:	333257   Click image for larger version
ID:	333265   Click image for larger version
post #15 of 15 (permalink) Old Feb 19th, 16, 6:22 PM Thread Starter
Yes, the bends in the pics are much tighter. It appears mine have been made short? Just going to have to do a bunch more work I guess. Thanks everyone.
msra4896 is offline
This Thread is more than 1390 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
