Window Squeaking - Chevelle Tech
Body Shop Paint & Body Forum
 2Likes
  • 1 Post By joehobrohe
  • 1 Post By suprdave1
post #1 of 6 (permalink) Old Jul 8th, 20, 10:32 PM Thread Starter
Window Squeaking
Hi everyone! We recently installed new Electric Life power windows as well as new window felts and now whenever we roll the window up or down, we get a horrible squeak. The stabilizers, stops, and bolts were all placed back in their previous position and the glass is not loose. We also used plenty of white lithium grease anywhere plastic moves against metal. All the felt on guides are in good condition and it is the original glass.
Here is a video of the windows moving up and down.
https://photos.app.goo.gl/PiqLCUAckTjsCDby6
Any ideas what can be causing this?
joehobrohe is offline
post #2 of 6 (permalink) Old Jul 9th, 20, 8:43 AM
Nick
Re: Window Squeaking
Just the one window? Doesn't look like there is much grease on the vertical alignment shaft...
Nick
Here's a link to my 2014 Camaro SS donor to 70 Malibu restomod project:
pcguy is offline
post #3 of 6 (permalink) Old Jul 9th, 20, 11:30 AM
Terry
Need more lube! Terry
68-13427 is offline
post #4 of 6 (permalink) Old Jul 9th, 20, 6:02 PM
I know exactly what that is. It’s the small brackets with the felt on the ends rubbing on the glass. More lube will not fix that. Make sure they are squared up on the glass surface. Then adjust them out a touch till the noise goes away.
As a test, pull the top of the glass out slightly while the glass is going up. I’ll bet the noise goes away.
Mine did the exact same thing when I put new brackets with the felt on. Had to swap out new felt with old felt. The new felt was crap.
SSJohn is offline
post #5 of 6 (permalink) Old Jul 13th, 20, 8:18 AM Thread Starter
This was exactly the problem! Thank you!!
SSJohn likes this.
post #6 of 6 (permalink) Old Jul 13th, 20, 9:51 AM
David Estes
My felts were worn out. I removed it and replaced it with the smooth part from a wide piece of Velcro. Problem solved
68-13427 likes this.
Have you ever stopped to think and forgot to start again??
suprdave1 is offline
