Bubbling in a few spots 2 months after paint sprayed. - Chevelle Tech
Body Shop Paint & Body Forum
 3Likes
  • 2 Post By Alwhite00
  • 1 Post By Mark66SS
post #1 of 14 (permalink) Old Jun 21st, 20, 3:33 PM Thread Starter
As title says I painted my elcamino 2 months ago and the paint has some bubbles in 2 or 3 small areas. I was using nason paints and everything was painted in perfect conditions on the same day at once. I’ll attach some pics below. Why is it doing this and is it going to get worse?
Edit: here are the pictures, although it looks like a run it is not, that was not there when it was wet sanded and buffed. Spots are on the tailgate and under the fuel door only.
https://imgur.com/a/DahKcl2
Polecat_Creek_Garage is offline
post #2 of 14 (permalink) Old Jun 21st, 20, 4:27 PM
Re: Bubbling in a few spots 2 months after paint sprayed.
Probably not the paint but what is underneath it.
IFLY and suazo66 like this.
67
70 (SOLD)
Alwhite00 is online now
post #3 of 14 (permalink) Old Jun 21st, 20, 4:59 PM Thread Starter
All the body work was stripped to bare metal and was prepped to perfection, epoxy primer from nason and hardly and body filler anywhere on the car.
post #4 of 14 (permalink) Old Jun 21st, 20, 5:44 PM
Mark
Pics wont load for me
66 SS 396 4 speed
63 Avanti 4 speed with factory air
60 Tbird convertible
69 AMX 390 4 speed
02 Springer Softail
03 Fatboy gone
12 Road Glide Ultra gone
everyday driver 07 3500 Dodge Ram Quad cab with a Cummins
72 c20 Chevy
68 c20 steepside
77 Suburban.
Mark66SS is offline
post #5 of 14 (permalink) Old Jun 21st, 20, 5:52 PM
Mark
Looked at them to me it looks like it's a rust pop. Have you tried cutting the bubble ? See what's under it. Definitely not a solvent pop. Did you use an acid etch? Nason doesn't call for one
66 SS 396 4 speed
69 AMX 390 4 speed
02 Springer Softail
03 Fatboy gone
72 c20 Chevy
68 c20 steepside
77 Suburban.
Mark66SS is offline
post #6 of 14 (permalink) Old Jun 21st, 20, 9:45 PM Thread Starter
I did not use and an acid etch, I don’t really want to cut the bubble yet but the inside of the tailgate looks Normal. If I mixed the paint wrong it would have shown up on the whole car but it’s only on the tailgate.
post #7 of 14 (permalink) Old Jun 21st, 20, 9:50 PM
Rame
Don't know how to help cause I hate paint and body work, but there is only one thing you can do to correct this problem and you know what it is. It sucks man but you are just going to have to buff it off and start over.
sampoerna415 is offline
post #8 of 14 (permalink) Old Jun 21st, 20, 10:32 PM
Terry
Where are the pics?
TerryAT is offline
post #9 of 14 (permalink) Old Jun 22nd, 20, 9:37 AM Thread Starter
Can’t be that bad because it’s only the top of the tailgate above the black stripe. So I can just repaint the tailgate top again.
post #10 of 14 (permalink) Old Jun 22nd, 20, 9:52 AM
Bart
Bubbles are one of 2 things, moisture or rust. Either way there is no fix other than cut it open and see whats under there. Since it is white you should not have any issues blending the the repair once you sort it out.
Bart_Swisher is offline
post #11 of 14 (permalink) Old Jun 22nd, 20, 1:28 PM
Mark
Your either going to have to live with it or cut it and redo the area. I have a few on my car the two that bother me are right above the drivers door so I see it everytime I get in the car. But I'm not fixing it I'll live with it till I redo the car. My paint 26 years old.
ID:	630804   Click image for larger version
68-13427 likes this.
66 SS 396 4 speed
69 AMX 390 4 speed
02 Springer Softail
03 Fatboy gone
72 c20 Chevy
68 c20 steepside
77 Suburban.
Mark66SS is offline
post #12 of 14 (permalink) Old Jun 22nd, 20, 1:38 PM
Mark
Originally Posted by TerryAT View Post
Where are the pics?
Ya have to copy and the url end of the post but here is one
66 SS 396 4 speed
69 AMX 390 4 speed
02 Springer Softail
03 Fatboy gone
72 c20 Chevy
68 c20 steepside
77 Suburban.
Mark66SS is offline
post #13 of 14 (permalink) Old Jun 23rd, 20, 6:17 AM
I think you might've have water laying in the jamb that made it's way down while you were painting.
Status: Car-Less
GRN69CHV is offline
post #14 of 14 (permalink) Old Jun 23rd, 20, 8:38 AM
Looks to me like the paint solvent lifted the body work. Did you use a sealer like an epoxy primer on top of the body work, before the paint?
69SS454 is offline
