67 rocker moldings too long? - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 7 (permalink) Old Jun 15th, 20, 7:56 PM Thread Starter
I put the wheel well trim on my 67 and am moon to the SS style rocker moldings. Problem being they are about 3/8" + too long to fit between the wheel moldings. Anyone run into this before? How did you fix it? I assume that they could be cut off but that would not be a correct end as they are rounded over now. Any suggestions?
67
70 (SOLD)
Alwhite00 is online now
post #2 of 7 (permalink) Old Jun 15th, 20, 9:54 PM
Pics?
67ss4spd is offline
post #3 of 7 (permalink) Old Jun 25th, 20, 2:08 AM
Ken
Re: 67 rocker moldings too long?
My '67 Chevelle's beltline moldings are the same way where they meet the wheel well moldings. I didn't restore it myself. I've had it for three years and didn't even notice the moldings are cut off until about a year ago. The ends of all the other moldings are rounded off as they should be. Oh well, I'm not trying to win any awards but the judges in three different car shows must not have noticed either as I have awards for "best of show", "best 60's", and "3rd place overall".
67 Chevelle Malibu, ZZ4 350 crate engine, TH350, FiTech EFI, Vintage Air, Dakota HDX dash, FlowMaster exhaust, Digi-Tails tail lights and front marker lights, 17" Rally style wheels, Redline tires
darksky is offline
post #4 of 7 (permalink) Old Jun 25th, 20, 6:35 PM
Cam
Cameron Milne
To get the result you want you may have to resort to snipping a little & rolling it on a brake or shaping with a selection of body hammers. Or just snip it. Or grind with a Dremel tool so you don't distort it.
I noticed on a few clones out there that they skipped the wheel opening moldings, which may either be due to the same said rocker length issue, or maybe it is because the repro wheel moldings are a far cry from factory in terms of fit.
Pics could definitely help here. Who knows, maybe you are sitting on Smokey Yunick's 7/8 scale Chevelle and that is why they don't fit. Is there anything funny with your gas filler neck?
"The more you know,
TC Gold #120
Cam is offline
post #5 of 7 (permalink) Old Jun 25th, 20, 7:04 PM
They’re pressed in a die but with some skill and patience you can probably cut them and with a good pair of small seamers slowly roll over the end so it doesn’t crack and just marry the corners. Those flutes may pose a little problem bending. Try finding a scrap one to see if it’s even possible? I know a guy who has one who’d probably give it up for 15-20 bucks.
ID:	631220   Click image for larger version
ID:	631222   Click image for larger version
ID:	631224   Click image for larger version
67ss4spd is offline
post #6 of 7 (permalink) Old Jun 25th, 20, 7:31 PM Thread Starter
I may have to lop it off and try to get it to bend slightly. The ribs will definitely be the issue. I may make an aluminum anvil and fold the end over it.
67
70 (SOLD)
post #7 of 7 (permalink) Old Jun 29th, 20, 1:28 AM
I got two pair of gm nos 67 rockers for sale. 256-366-6151
1966chevelleaholic is offline
