Rear Bumper Issues (66 Chevelle) - Chevelle Tech
Body Shop Paint & Body Forum
 10Likes
post #1 of 18 (permalink) Old Jun 11th, 20, 11:54 AM Thread Starter
Andy
Alright TC, looking for a lil help on this one. The rear bumper is shifted to the passenger side and I'm having trouble figuring out why. The driver side is touching the rearmost portion of the quarter and the passenger side is sitting off the quarter ~1". I'll give as much detail as possible, nothing is welded in place yet...all secured with vice grips or self-tapping screws
1.New frame
2.New trunk pan is sitting properly on brand new bushings and both sides are snugged tight, correct bushings (top & bottom) have been double checked
3.New rear tail panel is placed properly (I believe) and shows equal hang over on the trunk pan flange
4.New quarters are secured flush against rocker panel and each side snug to tail panel and secured with ST screws
5.New package tray and deck filler panel are secured place and well within fitment spec and deck filler is secured to quarters with ST screws
6.New bumper, new bumper brackets and new hardware
7.Bumper & brackets are hand tight to each other and to the frame
8."Peak" of the bumper is centered on the fuel neck notch in the frame
Happy to take any other pics/provide any other info that may help kick me in the right direction. TIA
ID:	629772   Click image for larger version
ID:	629774   Click image for larger version
ID:	629776   Click image for larger version
HappyRtFt is offline
post #2 of 18 (permalink) Old Jun 11th, 20, 12:13 PM
Re: Rear Bumper Issues (66 Chevelle)
My first thought is the brackets...............
68-13427 likes this.
66 Malibu
busterwivell is online now
post #3 of 18 (permalink) Old Jun 11th, 20, 12:27 PM Thread Starter
Andy
When I get back to the shop it's worth another look to see if I connected them incorrectly....stranger things have happened, right?
Kirk's67SS likes this.
post #4 of 18 (permalink) Old Jun 11th, 20, 1:31 PM
Greg.
New Bumpper out of whack !?
Find Reference places and Measure the Ends Gap for each side of the Bumper and compare
Measure from the Center/Peak Line of Bumper to Each End of the Bumper and compare
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #5 of 18 (permalink) Old Jun 11th, 20, 1:36 PM Thread Starter
Andy
Didn't think of the simple step..thanks Kirk.
post #6 of 18 (permalink) Old Jun 11th, 20, 1:42 PM
Cody
How's the body in relation to the frame? Has it been lined up using the holes in the frame and braces?
floyd66 likes this.
1971 Monte Carlo
Blackhawk is online now
post #7 of 18 (permalink) Old Jun 11th, 20, 2:08 PM
I can't tell in that one shot, but do you have the center bracket installed & bolted to the frame? The center bracket pulls the bumper in & up & the sides move accordingly.
Loosely bolting it up won't really show you where you're at. The holes in the brackets are over sized to allow for adjustment. You should be able to get some side to side movement just by sliding the bolts around.
Also, you really should install the quarter panel extensions in order to line it all up correctly.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is online now
post #8 of 18 (permalink) Old Jun 11th, 20, 2:19 PM
with all the parts you have replaced i also would say the body is not sitting on the frame square.as mentioned,put the tail light housings on it will make it easier,then adjust accordingly,and by the looks of it the trunk lock hole looks like it is to the left of center of the bumper
cherokeepeople is online now
post #9 of 18 (permalink) Old Jun 11th, 20, 2:24 PM
Measure from the frame to a reference point on each 1/4. I'm guessing you need to shift the body over on the frame.
67
70 (SOLD)
Alwhite00 is online now
post #10 of 18 (permalink) Old Jun 11th, 20, 2:40 PM Thread Starter
Andy
Thanks everyone, I will go through each of the suggestions and report back. I do appreciate the input.
post #11 of 18 (permalink) Old Jun 11th, 20, 5:15 PM
Greg.
Andy here are pics of my 67's Bumper
just a small/pinky finger width on the DriverSide
even less on the PassengerSide
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #12 of 18 (permalink) Old Jun 11th, 20, 5:40 PM
Hank
Look at your bumper pictures from above. There is a big difference from one side to the other in the distance of the v shape of the bumper and its the way it's showing off.
RAIDER SS likes this.
HKalin is online now
post #13 of 18 (permalink) Old Jun 11th, 20, 10:34 PM
David
Gotta Gotta Gotta do this first! What with all the work that has been done on the car - the body has to be centered on the frame or you'll be chasing more issues down the road than just a bumper!
Take several left / right measurements starting from the front of the car & work your way back to the rear of the car.
And I agree with Hanks observation as well!
66 Malibu......back to life, now with a 427 BB & 4 speed
RAIDER SS is offline
post #14 of 18 (permalink) Old Jun 13th, 20, 7:24 PM Thread Starter
Andy
Progress!, I think I got her figured out. I added the drop-offs/extensions and that seemed to do it....nothing needed to be jammed in, everything went into place as expected. I'll work on the driver side tomorrow before declaring victory on this item. Thanks for the help TC, you all are the best!
ID:	630050   Click image for larger version
ID:	630052   Click image for larger version
ID:	630054   Click image for larger version
ID:	630058   Click image for larger version
Kirk's67SS, HKalin and davewho1 like this.
post #15 of 18 (permalink) Old Jun 13th, 20, 7:47 PM
Looking good
67ss4spd is offline
