Fender Extension Nuts... - Chevelle Tech
Body Shop Paint & Body Forum
 2Likes
  • 2 Post By caminonut
post #1 of 12 (permalink) Old Feb 13th, 20, 10:49 PM Thread Starter
I am need of one fender extension nuts for my 71. The extension was rattling, so I took the nut off and tried to 'tighten' it up a bit (basically bent the center of the nut in a bit). Now I can't get it to go back on (I tightened it too much). Does anyone sell these nuts without them being in a kit with several other pieces?? Let me know. Thanks.
My Chevelle w/ open headers:
WakkoWarner is online now
post #2 of 12 (permalink) Old Feb 14th, 20, 7:37 AM
Re: Fender Extension Nuts...
Hello Brian,
Send me your address in a PM and I will put 2 in an envelope and send to you.
RealRed70 and Hotwire like this.
caminonut is online now
post #3 of 12 (permalink) Old Feb 14th, 20, 8:45 AM
Very nice of you John!
If you ever need more, your local napa has a catalog with all the fasteners vacuum sealed to pages that you can look through to find a match. Normally they're in bags on a carousel somewhere in the store.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #4 of 12 (permalink) Old Feb 14th, 20, 10:05 AM
I actually threaded the posts on my 72 fender extensions and use washers and lock nuts to secure it.
72soft-top is offline
post #5 of 12 (permalink) Old Feb 14th, 20, 10:55 AM Thread Starter
Originally Posted by caminonut View Post
Hello Brian,
Thank you. PM sent.
post #6 of 12 (permalink) Old Feb 14th, 20, 11:12 AM
Originally Posted by WakkoWarner View Post
Thank you. PM sent.
Hello Brian,
Here are Pictures, Will have them out in the mail to you today.
ID:	616502   Click image for larger version
post #7 of 12 (permalink) Old Feb 14th, 20, 11:28 AM Thread Starter
Is there a way to make sure that these stay tight?? I have never had good luck with them (I had to change out the driver side fender extension, because one of the studs broke off - not from me tightening, but just from being too loose for too long).
post #8 of 12 (permalink) Old Feb 14th, 20, 11:31 AM
Not sure on that, I have never had a problem with any being Loose.
post #9 of 12 (permalink) Old Feb 14th, 20, 2:37 PM
Don
On one of my previous Chevelles they were so damaged they wouldn't stay tight. I cut the stud off and drilled and tapped it. Worked like a charm and kept them tight
Don
'72 Malibu Convertible
TC #4782
Lincoln, Ne
MidLife72 is offline
post #10 of 12 (permalink) Old Feb 14th, 20, 3:40 PM
I just had mine off and back on. I had a couple that were broke off too. I drilled and tapped the holes and used 1" long set screws, JB Welded in the holes, then used regular nuts & fender washers. I also used some 3M Strip Caulk under the washers to seal the holes and 'lock' the nuts. My tail lights were dim so I pulled them off to paint the bulb reflector area with 'chrome' spray paint. It made a huge difference in brightness.
69SS454 is offline
post #11 of 12 (permalink) Old Today, 7:51 PM Thread Starter
I received the nuts today. I used one and it threaded right on. Thanks again.
post #12 of 12 (permalink) Old Today, 8:13 PM
Cory
I cross thread stuff that I want to stay tight. No need for loctite.
dream66 is online now
