Process for remounting fenders and core support. - Chevelle Tech
Body Shop Paint & Body Forum
 3Likes
  • 1 Post By stanski
  • 1 Post By Pete 67
  • 1 Post By bjl95mustang
post #1 of 6 (permalink) Old Feb 13th, 20, 4:08 PM Thread Starter
Brandon
I purchased this 71 last year and Iím fixing a few issues. The previous owner replaced the core support. When I replaced the body bushings I found the core support bushings installed wrong.
Iím redoing the a/c and replacing the door hinges so I have the fenders off and the core support loose right now.
Iíve got the door hinges replaced and the door realigned. I have a pretty good idea on how to get the fenders aligned but how is that done with the core support. Do I get everything hand tight then measure corner to corner in the engine bay? Then adjust from there?
1971 Chevelle Malibu, 383 Stroker, Antique Green with White Roof. (Heavy Chevy knock off)
bjl95mustang is offline
post #2 of 6 (permalink) Old Feb 13th, 20, 4:26 PM
Re: Process for remounting fenders and core support.
The only things you should worry about with the core support:
  1. It is square with the frame (I usually do this with the bumper up to make sure it passes the eye test).
  2. The tilt of the fenders, so you would shim the core bushings as needed. Just follow the body lines and make sure the gap is even between the fender and the door at the top and bottom.
  3. The distance between the fender and the door. I normally make it 1/8" gap. Factory manual calls for 1/16" tolerance, and 1/16" between the fender and the rocker.
Though I have found it is kind of a pain with aftermarket parts. You'd have the bolts hand tightened until you get it the way you want using shims.
BluesBoy721 is online now
post #3 of 6 (permalink) Old Feb 13th, 20, 9:25 PM
Terry
Dan, what reference points did you use to square the core support to the frame? Thanks, Terry
68-13427 is offline
post #4 of 6 (permalink) Old Feb 14th, 20, 11:11 AM
Stan
I set the core support in place with the new bushings leaving the bolts loose. Then loosely hang the fenders and set the front of door to rear of fender gap adding shims to the core support as required. Then tighten up the fender bolts to hold that gap. Measure hood opening from corner to corner to get it as square as possible by sliding the core support side to side as required. Then drop in the hood and tap the core support side to side again as needed to get the fender to hood gaps even. Now you give the core support bolts a final tightening and add more shims as necessary as the compressing rubber may change the door to fender gap. The core support is now set in place and you can take off the fenders and hood if needed.
68-13427 likes this.
stanski is offline
post #5 of 6 (permalink) Old Feb 14th, 20, 1:35 PM
After loosely bolting up the radiator support and before installing the fenders, I gently lay the inner fenders over the tires & get a few of the front bolts started. After you install the fenders, it makes it very easy to finish installing the inners without scratching anything.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is online now
post #6 of 6 (permalink) Old Feb 15th, 20, 12:13 AM Thread Starter
Brandon
Thanks everyone for the help. I didn't realize how much play there was on the body till I got everything taken apart. This will help me when I put everything back on.
I'm just waiting for all of the a/c parts to come in so I can re install the evap box and put the car back together.
I know something was definitely off because the condenser was hitting the lower support bar right in the middle. it wore a hole right through the condenser.
David Bates likes this.
