Front Corners Of Hood Up - Chevelle Tech
Body Shop Paint & Body Forum
 3Likes
post #1 of 24 (permalink) Old Jan 3rd, 20, 9:50 AM Thread Starter
69 Chevelle, front middle is down maybe an eight from front filler. Each corner is up less than an eight from filler and fender corners, not touching rubber bumpers.
Seems to me both front fenders need raising up (I have neither the skill or patience for this). Or I need to put some “bow” back in hood (no way would I try this on a painted car)
Back edge fits OK
Any other suggestions ?
Reelysalty is offline
post #2 of 24 (permalink) Old Jan 3rd, 20, 10:08 AM
Re: Front Corners Of Hood Up
Raising the front of the fenders increases the door gap at the bottom.
post #3 of 24 (permalink) Old Jan 3rd, 20, 10:56 AM
Cody
Are any of the parts aftermarket or new to the car? Is the hood latch set very tight?
I agree with Dean on the fender to door gap, but check to see how your gaps are. How does the fender look compared to the rocker panel? Is the hood even with the fenders everywhere but the front?
1971 Monte Carlo
blackhawkMC is offline
post #4 of 24 (permalink) Old Jan 3rd, 20, 9:27 PM Thread Starter
The hood latches by itself when I start to close it.
Pretty sure there’s plenty of aftermarket parts.
Hood front corners are up. Rest of hood/fender fit is OK with me.
post #5 of 24 (permalink) Old Jan 4th, 20, 5:15 PM
Terry
Is the '69 hood latch the same as the '68? If so it is adjustable, on the hood side of the latch , it screws in or out. Terry
68-13427 is offline
post #6 of 24 (permalink) Old Jan 4th, 20, 5:59 PM
Mark
Loosen the front bolts on the hood hinge mounting points on the fender to tip the rear of the hood down. Sounds counter intuitive but it works.
modern malibu is offline
post #7 of 24 (permalink) Old Jan 7th, 20, 8:51 AM
Mr Bill
You might just have to do this. Can you post a picture looking straight at the front of the car with the hood closed ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #8 of 24 (permalink) Old Jan 7th, 20, 6:06 PM Thread Starter
Good idea. Front of car is on jacks, giving a different (higher) perspective. Looks like both rear corners could rotate down a little ?
Pick front of hinges up some ??
Hood actually is bowed up on both sides. I always attributed this to slamming hood w/dry hinges ?
ID:	612904   Click image for larger version
ID:	612906   Click image for larger version
ID:	612908   Click image for larger version
post #9 of 24 (permalink) Old Jan 8th, 20, 8:57 AM
Willie
Lube your hood hinges up, as I use Sea Foam Deep Creep on all 7 rivets on each hinge. Hit the backs of the rivets and in each joint, where you have metal to metal movement and work the oil into those joints. Should make the hinges seat better on the cowl, and never use dry hinges, as they need lube as well.
Willie
70 SS 454 Chevelle
72 SS 402 Chevelle
72 Monte Carlo 350
68 SS 396 Chevelle
2018 Malibu LT
see pics of them at
WillW23 is offline
post #10 of 24 (permalink) Old Jan 8th, 20, 9:08 AM
Mr Bill
I thought you said it was the front that was not aligned correct ??? That is the back of the hood not the front.
Is the hood shut all the way and latched in those pictures ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #11 of 24 (permalink) Old Jan 8th, 20, 10:13 AM Thread Starter
Some pics of front, middle, sides and back.
Hinges are well lubed
post #12 of 24 (permalink) Old Jan 8th, 20, 9:16 PM
If it’s bowed in the middle the front has to come down.
67ss4spd is offline
post #13 of 24 (permalink) Old Jan 9th, 20, 7:43 AM Thread Starter
Yes, but front middle is already below front filler at wind split
(see pic)
post #14 of 24 (permalink) Old Jan 9th, 20, 11:10 AM
Did you set the latch depth and hood bumpers?
67ss4spd is offline
post #15 of 24 (permalink) Old Jan 9th, 20, 7:47 PM Thread Starter
Hood corners are too high, bumpers
not holding hood up. If center adj higher, corners even higher
