1970 Chevelle Hood Adjustment - Chevelle Tech
Body Shop Paint & Body Forum
 4Likes
  • 1 Post By 72soft-top
  • 1 Post By pcguy
  • 1 Post By edsvet
post #1 of 8 (permalink) Old Dec 4th, 19, 6:21 PM Thread Starter
I have an issue with my 70 Chevelle hood. The passenger side rear is raised. I know I have seen before that you need to do the opposite of what you think to adjust. Some years ago I tried this on my drivers side and wound up putting a large scratch on fender. Thanks for any help! Ed
ID:	610010   Click image for larger version
edsvet is offline
post #2 of 8 (permalink) Old Dec 4th, 19, 7:43 PM
re: 1970 Chevelle Hood Adjustment
Ed -
Basically the passenger hinge needs to be adjusted up. Like you said, it's kind of counter-intuitive, but that will cause it to close further which in turn will drop it.
jim
Jim's69Ragtop is offline
post #3 of 8 (permalink) Old Dec 4th, 19, 10:54 PM
Re: 1970 Chevelle Hood Adjustment
https://www.chevelles.com/forums/12-...alignment.html
post #4 of 8 (permalink) Old Dec 5th, 19, 9:46 AM
If I remember correctly, my hood moved like that after it was painted. I loosened the forward bolt on the hinge, then lifted the open hood slightly higher to rotate on the rear hinge bolt. Then tighten and check fit. Repeat as required
One thing I always do is use 2 hands to raise the hood evenly. If you raise using one hand on a side, the hood tends to cock slightly when raised.
edsvet likes this.
72soft-top is online now
post #5 of 8 (permalink) Old Dec 5th, 19, 11:16 AM
Nick
Once in a while, the issue is that it just needs some lubricant...
Nick
edsvet likes this.
Here's a link to my 2014 Camaro SS donor to 70 Malibu restomod project:
pcguy is offline
post #6 of 8 (permalink) Old Dec 5th, 19, 1:01 PM Thread Starter
Thanks for the detailed answer! Ed
edsvet is offline
post #7 of 8 (permalink) Old Dec 5th, 19, 7:19 PM Thread Starter
Got this time without scratching anything! Thanks again for the help!
Hotwire likes this.
edsvet is offline
post #8 of 8 (permalink) Old Dec 5th, 19, 10:52 PM
Looks good. Glad it worked out.
edsvet likes this.
