media blasting or a waste of money? - Chevelle Tech
Body Shop Paint & Body Forum
 13Likes
post #1 of 16 (permalink) Old Dec 2nd, 19, 9:22 AM Thread Starter
jeremy
Hello all,
I have the body off the frame of my "66 and I will be replacing full floors, trunk panel, tail panel, quarters, roof skin, wheelhouses etc. Is it worth having the car blasted prior to the work or should I just clean the paint off at the spot welded joints and remove/replace the panels? I've been going back and forth on what to do. The blasting gives a nice clean surface to work with but is it necessary? Any advice would be appreciated thanks!
mercmd is offline
post #2 of 16 (permalink) Old Dec 2nd, 19, 9:49 AM
Re: media blasting or a waste of money?
I would have it blasted. Have them concentrate on the panel areas you dont plan to replace. Sometimes you find surprises that re-calibrate your bodywork plans.
von, Kirk's67SS and 68-13427 like this.
Ed C.
70 SS Gold L34 Auto
57 Belair hardtop project
Always looking
EdCarpenter is online now
post #3 of 16 (permalink) Old Dec 2nd, 19, 12:16 PM
Will
I know for me, the biggest thing about taking it to the blaster is the hassle of taking it to the blaster. If it all possible, that is the route that I would take. Most of my car was in repairable condition, but I wish that I had gone that route initially. I sanded mine, and then came back with naval jelly and steel wool on the panels to remove any surface rust. I am still going to blast mine in all of the confined spaces, fire wall, floor pan, etc. Blasting is the only efficient way in my opinion to get clean metal. The flat stuff can be cleaned up really well with the naval jelly/ steel wool, but seams terrify me because the acid will keep eating away at it if you don't get it out. The trouble in my opinion is finding someone who you trust not to destroy the flat panels in the process.
yelchevelle is offline
post #4 of 16 (permalink) Old Dec 2nd, 19, 1:03 PM
Find somebody that combines the media blast material with high pressure cold water. This will stop any chance of overheating your flat panels into warping and the metal will be fine.
B52bombardier1 is offline
post #5 of 16 (permalink) Old Dec 2nd, 19, 5:34 PM
Dustlessblasting.com
Freddy Mercado likes this.
Jeffs68ss is offline
post #6 of 16 (permalink) Old Dec 2nd, 19, 6:19 PM
Brace it up and strip the old stuff off first, gets you to the meat of the repairs cleaner and to the finish line easier, faster, cleaner. Soda, acid dip or water blasting.
67ss4spd is offline
post #7 of 16 (permalink) Old Dec 2nd, 19, 6:42 PM
WRONG WRONG WRONG WRONG!!!!!!
This is nothing but pure internet forum BS that somehow gets regurgitated time and time again!! The metal is NOT damaged due to heat, it is damaged due to millions upon millions of particles of sand acting like hammers and peening the surface, stretching the metal.
Excessive pressure, wrong angle and wrong grit play a factor in warping metal when blasting, heat is NOT even remotely in the same ballpark.
Water blasting would be one of the last methods I'd use, wet sand packed in tight areas, have fun getting that all out.
I would brace the car, cut out the quarters and roof skin and have the entire car blasted, then put into epoxy primer.
IMO, the best media would be two fold, first plastic beads to remove any paint, then glass beads for rust removal.
1949 and 1972 chevy trucks
Pictures of my work
sevt_chevelle is offline
post #8 of 16 (permalink) Old Dec 4th, 19, 11:06 AM
Lou
[QUOTE=sevt_chevelle;11188830]WRONG WRONG WRONG WRONG!!!!!!
It's both. More of what your saying than the heat , but the metal does heat up some due to friction and when that happens and the sand hits the metal it will stretch. I've been the route of the sand blasting and the only places I do it now is where it was impossible to do anything other than blasting. Small areas where rust was bad was the only places I did it in. Everything else was Phosphoric Acid if you can submerge it and good quality stripper and a ton of paper towels and rubber gloves. All the paint on the body was removed using stripper and paper towels and hand sanding. Lots cheaper and easier than the logistics and results of any kind of blasting. Remove the paint then submerge small pieces in phosphoric acid. Which you can find at HD for cheap. Wheel rims and thick metal is the only place I would use sand blasting on. If it's just surface rust you can wire brush it with different sizes of wire wheels, wear safety glasses) and then give it a few coats of red oxide primer or as is commonly known as Rusty Metal Primer. This stuff works great. They treated a rusty U-Boat with it in Europe. Also cheap and easy to apply. I did my frame that way and there's not a spot a rust that materialized in the two years it sat under my canopy with a tarp over it in the back yard with the summer rains so I'll swear by the stuff. Of course I'm going to catch flak but I'll argue my method till the cows come home.
1943MB is offline
post #9 of 16 (permalink) Old Dec 4th, 19, 5:34 PM
I do the rust repair first ON THE FRAME. Then have the body blasted on the rotisserie. I have a guy that knows what hes doing and has never given back a warped panel on any of the cars Ive had him do.
BlueSS454 is offline
post #10 of 16 (permalink) Old Dec 4th, 19, 7:47 PM
hi
either
1/ chemical bath complete car body
or 2/ soda or walnut blast. If car body is on a rotisserie do at home
Blasting leaves rubbish behind . May not be able to remove .
. There are many ways to strip a car chemically . Following is one single procedure .
1/ baking till all sealer paint falls off
2/ pressure wash
3/ alkaline strip tank
4/ pressure wash
5/ heat in oven to dry
6/ spray with charged/ magnatized weld thru primer
swampy 6x6 is offline
post #11 of 16 (permalink) Old Dec 4th, 19, 11:58 PM
Logan
As someone who was a media blaster and powdercoater for ~5 years for a living...
Soda blasting was a waste of material and time. If you're working on anything other than magnesium, there is better media out there.
I personally used 100 grit aluminum oxide. The material is recyclable and is broken down over the first run through the machine, so the grit wasn't as heavy as some might think. Read mention about wrong angle and this couldn't be more correct. Panels can warp from heat from direct blasting, it's really not complicated to just move around the car. Section the car off into squares and constantly move around. Just brings the heat along with it instead of focusing in one main area. I personally haven't had the chance to use "dustless blasting", but from what I could tell, it still uses media, so again if someone just kept 'er movin, they should be perfectly fine. Scariest item I had to blast was a Ferrari Belly Pan.. perfectly fine.
Attached a photo of my car before and after blasting.. Guess what area I didn't had any issues (hint: above the wheel well rust was a NICE surprise)
64 Chevelle SS
logan64 is offline
post #12 of 16 (permalink) Old Dec 8th, 19, 4:01 PM
Just like Eric said. Heat from blasting is not the cause of warping. Compressive forces warp panels. A few blasting shops around here with over 40 years in the blasting business know this. I've been in the collision and resto business for decades and have blasted panels without warping them. You can use sand at a lower pressure, correct finer media size, angle and distance to prevent warping. Very clear explanation in the first post, no reason to read any further. https://www.hotrodders.com/forum/san...yth-76938.html A friend of mine who has been blasting for decades was also in the dark about the heat myth until I explained it to him.
Raven1 is offline
post #13 of 16 (permalink) Old Dec 8th, 19, 9:55 PM Thread Starter
jeremy
Ive actually decided it's a waste of money in my scenario. I am replacing nearly every body panel and full floor/trunk as well so why prep what i'm removing? I have the car on a rotisserie now in my shop at home and I removed the floor and rockers today after bracing the body wow there are a lot of spot welds.......
mercmd is offline
post #14 of 16 (permalink) Old Dec 9th, 19, 1:47 PM
Jared
If you remove the rotted metal then have the bare shell sandblasted and epoxied, you will have metal that should last decades more.
Sent from my LM-G710 using Tapatalk
Crazychevelle67 is offline
post #15 of 16 (permalink) Old Dec 9th, 19, 2:36 PM
If I ever take on another rust bucket, it's going to be fully blasted. I want to start with totally clean and fully exposed metal to begin with.
Kopfjaeger likes this.
Protesting should not be a license for anarchy.
Alan F is offline
