Floor pan - Page 2 - Chevelle Tech
Body Shop Paint & Body Forum
 3Likes
post #16 of 24 (permalink) Old Nov 13th, 19, 9:16 PM
Re: Floor pan
a
ss454conv is online now
post #17 of 24 (permalink) Old Nov 13th, 19, 9:18 PM
Re: Floor pan
b
post #18 of 24 (permalink) Old Nov 13th, 19, 9:19 PM
Re: Floor pan
c
ID:	607944   Click image for larger version
post #19 of 24 (permalink) Old Nov 13th, 19, 9:21 PM
Re: Floor pan
Kstuck67 and ss454conv,
Thank you for your thorough replies. I now fully understand what bluess454 meant. You guys are an invaluable resource. Thank you!
My 72 is all original rusted out. I'm not sure it has been on the road in the last 20 years. It's a very neglected. I just recently completed the trunk. I thought it went well and was easy by the end.
This full floor and firewall is no walk in the park. I pulled the front quarters and wheel wells today. Vacuumed out all the rust dust. Installed a shop light in the roof. I'm going to buy a few sticks of 1" square tube and get to bracing.
Sent from my SM-G960U using Tapatalk
TheBoatWhisperer is offline
post #20 of 24 (permalink) Old Nov 16th, 19, 9:12 PM Thread Starter
Re: Floor pan
Thank for all the info. Very helpful!
IRISHHANDS is offline
post #21 of 24 (permalink) Old Nov 17th, 19, 7:57 AM Thread Starter
Originally Posted by BlueSS454 View Post
Do it on the frame. To be honest, it would have been easier to do a floor with rockers as opposed to doing it separate. Make sure the A pillar braces and front cowl shoulders are good. If not, replace those as well.
Sounds like you have done a few. Body is on frame. I cut out old floor. Slide new floor in from top. Get in place and put bolts in. Then begin securing using screw and then start welding? just trying to get a basic idea of what your saying? If floor is pur in from top? Do you remove inner rockers and braces from new floor?
Thanks in advance
post #22 of 24 (permalink) Old Nov 17th, 19, 8:06 AM
Re: Floor pan
Also . . . be very careful to not cut the floor support braces unless you plan on replacing them. Fortunately for me, my floor support braces were in good shape but I did have to drill some "landmark" holes from the bottom of the floor near the edges of the braces (drill up into the cabin) so that I could see where to cut floor metal from above.
B52bombardier1 is offline
post #23 of 24 (permalink) Old Nov 17th, 19, 5:53 PM Thread Starter
Thanks Rick!
post #24 of 24 (permalink) Old Dec 18th, 19, 9:31 PM
Re: Floor pan
I need a floor in my 71. My inner and outer rockers are near perfect so do I really want just the floor or floor with inner rockers? It seems like people say its easier to do the floor with the inners. I am planning on using AMD floor pan. Thoughts?
70CHEVYBB is offline
