Old procedure for repair of dent in the side and wheel well area - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 6 (permalink) Old Oct 11th, 19, 5:42 PM Thread Starter
I was looking at a used chevelle and there was kind of a repair to the rear quarter at the top of the wheel well area. At first I thought rust; but no rust in any of the usual areas except for bottom of trunk, probably due to water.
In the right rear quarter outer wheelhouse the top outside had been cut out and two odd patches braised in with a total dimension about 12” wide and 6” high. Otherwise inner and outer wheelhouses untouched with 50 year old undercoating still attached as on day one.
When checking the outside of the quarter in this area with a light magnet about 15” by 1 1/2” high just above the molding it would not stick. Maybe to light a magnet or thick bondo. All the other areas like lower rear and front just to the rear, etc held the magnet. Looked good from trunk; but couldn’t see down far enough. This would be a common rust area. Other side perfect as well as drop offs and lower rear tail panel. AZ car.
Was it common when fixing a dent/ damage to this area to cut out the wheelhouse on the inside to pound out and repair the damage that way? That’s my guess; but could be rust. Would like to know what I am getting into should I buy the car? Thank
Jim_66SS is offline
post #2 of 6 (permalink) Old Oct 12th, 19, 9:21 AM
Re: Old procedure for repair of dent in the side and wheel well area
That is possible so they could hammer and dolly outside of 1/4 .
Chevys#1 is offline
post #3 of 6 (permalink) Old Oct 12th, 19, 10:46 AM
Greg
Dent repair has always been to remove the bent in the opposite direction it went in, by what ever means necessary.
Life is too short for caring about every bodies else's stuff
Grock-co is offline
post #4 of 6 (permalink) Old Oct 12th, 19, 12:05 PM
I say it is a red flag either way.
whether a dent repair or rust repair.
Sounds like work was done to the wheel lip area and
somebody wanted to see the back side for what ever reason.
I remember brazing a couple small patches in back in the day before affordable
mig welders were accessible. A lot of wavy metal and filler was my result.
LKN BCK is offline
post #5 of 6 (permalink) Old Oct 12th, 19, 12:12 PM
Most likely rust repair
post #6 of 6 (permalink) Old Oct 12th, 19, 1:24 PM Thread Starter
Most likely rust yes; but why cut a hole in the outer wheelhouse and leave its patch paint and undercoat free so Its obvious someone was inside there? Can't find evidence of rust anywhere, not on lower rear quarters, lower front rear quarters, not rocker pinch-weld area, not on floor, not behind the kick panels, not on the lower rear of the front fenders, not on the pinch-weld of the inner door & door skin, not up in the front truck cross-member, not anywhere along where the truck floor is spot welded to the inner wheelhouse, not on the rear truck floor brace. Only evidence I find is the bottom area of the truck pan (about a 120" diameter circle in the center.
Assuming rust, how big a repair and repair cost is it going to be?
Jim_66SS is offline
