Installing Full Trunk Floor - 69 Chevelle - Page 2 - Chevelle Tech
Body Shop Paint & Body Forum
 10Likes
post #16 of 22 (permalink) Old Oct 9th, 19, 1:48 PM
Re: Installing Full Trunk Floor - 69 Chevelle
Originally Posted by slowmo55ss View Post
I agree except when trying to save the connecting lip or panel for reuse or fitment
Thatís not really an issue if you use the air chisel correctly with the right bit on it.
BlueSS454 is offline
post #17 of 22 (permalink) Old Oct 9th, 19, 2:48 PM
Terry
Auto body surgery if you will. Terry
68-13427 is offline
post #18 of 22 (permalink) Old Oct 10th, 19, 8:52 AM Thread Starter
Hector
Send a message via Skype™ to HERodriguezJr
You absolutely need to do this job on the frame. I just cut the whole back end off, but you can do it without removing the quarters. The drop offs will be wasted as well.
You're brave. Any alignment issues? Also, what type of sheetmetal did you use? I hear people brag about AMD all the time. I think they're all the same tbh. I purchased all Goodmark.
Thanks!
HRodz
1969 Chevelle Malibu
350 SBC (soon to be BBC)
4 Speed (soon to be T56)
10 Bolt 8.2 Rear (soon to be 12 bolt)
HERodriguezJr is offline
post #19 of 22 (permalink) Old Oct 10th, 19, 9:02 AM
Thanks!
I do this type of work for a living so itís like second nature. I always cut them apart like this. Floors and trunk floors, and inner pieces I normally use Dynacorn. Iíve also used AMD.
post #20 of 22 (permalink) Old Oct 10th, 19, 11:13 AM
I did my convertible in stages. Convertible have a fairly strong underbrace system so fix anything that touches that. MEASURE and MEASURE again. Make sure the frame is straight and strong. You will obviously lift the body off the frame a few inches. I believe I fixed my inner and outer fenders first. My convertible had a lot of rust and I didn't want to deal with rust popping through someplace not changed. Floors and trunks regardless if rusty do offer quite a bit of strength so they are last to be cut out.. In my case I went all AMD and they are not the same as others. After you repair the inners and outer fender connect them to the exact location as before to the inner braces then you can remove the rear panel. My quarters were so bad I cut them off to the upper belt line. After removing the rear valence (easy) I slid the new trunk in from the rear but only after drilling out a lot of spot welds. I did my trunk and complete floor but do the trunk first and the floor full with braces and inner rockers after the trunk in done. Don't forget to install the new trunk extensions and rear braces while the quarters are off. Lower the car back down and locate on the trunk frame mounts and double check that your trunk mounts lines up as well as the floor and forward mounts, The tack weld in place and finish weld after everything lines up. Sorry about the rotated pics
Name:	Chevelle trunk.jpg
ID:	605184   Click image for larger version
Name:	Chevelle floor.jpg
Billdini is offline
post #21 of 22 (permalink) Old Oct 12th, 19, 9:29 AM
I started my trunk project today, as well. Mother nature has done most of the work for me.
Sent from my SM-G960U using Tapatalk
TheBoatWhisperer is offline
post #22 of 22 (permalink) Old Feb 16th, 20, 2:50 PM
Bruce
Thanks, @NickeyChevelle . I just watched some of your videos also. Great work. Yes, I agree.. the less I remove, the better. Did you brace the rear of your car?I might cut only the bottom parts of the 1/4's, then work my way up. My inner and outer wheelhouses, and trunk drop off's need to be replaced. Basically, the WHOLE rear of the car. I have all of the Goodmark sheetmetal already. It's just a matter of time at this point.
The Quarters, outer Wheelhouses, Drop Offs, and 1/3 of the trunk floor were replaced. No to bracing, BUT I had a shop do the body. As I recall, only one side was removed at a time...
Our You Tube Vids:
NickeyChevelle is offline
