Empty Engine Bay - Chevelle Tech
Body Shop Paint & Body Forum
 2Likes
post #1 of 18 (permalink) Old Oct 7th, 19, 9:24 AM Thread Starter
Empty Engine Bay
Hi
I removed my big block for a full rebuild and now have an empty, grimy and old engine bay.
This includes firewall, cowl, frame, suspension, (inner fenders are out and replacing with new ones)
I would like to take this opportunity to do a cleaning, painting and some restoration on all the pieces (including wires, grommets and accessories etc.)
Wondering if anyone has done this effort and can provide some guidelines/tips
If there is any existing threads on this let me know.
Thanks!
Mario
1969 SS396
MarioSS396 is offline
post #2 of 18 (permalink) Old Oct 7th, 19, 7:41 PM
Re: Empty Engine Bay
If you're running headers this would be a good time to relocate the brake line and combo valve away from them.
Jerry70 is offline
post #3 of 18 (permalink) Old Oct 7th, 19, 8:29 PM
I second that. I replaced the distribution block on mine. I didn't notice it when I installed it but the mounting bracket is slightly different from the original. The block seems to be a little further away from the bend in the bracket which makes it further from the frame. I reinstalled my engine 2 weeks ago and now my header is resting against it.
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is offline
post #4 of 18 (permalink) Old Oct 7th, 19, 8:30 PM
Pressure wash all of the area you describe and prep it for some Hot Rod Black single stage paint. This process will never be easier than right now. Fill holes in the firewall that won't be used during or after the rebuild.
Figure out what company aftermarket air conditioning kit, if any, that you might be considering and set up its firewall mounting plate while the access is easy.
I'm sure there are things that I'm forgetting but let's see what others say.
B52bombardier1 is online now
post #5 of 18 (permalink) Old Oct 10th, 19, 10:11 AM Thread Starter
Thank you for the great responses
Next question:
Would it be better to install my (metal) inner fenders while the engine is out or should I do it once it is in?
post #6 of 18 (permalink) Old Oct 10th, 19, 10:44 AM
Bart
I recommend a serious pressure wash, as the others have said move the distro block. Then sand/maroon scotch brite the entire area and either paint with semi gloss or my personal favorite SPI Black Epoxy Primer. It is as durable as can be and has a very nice semi gloss look when finished. Do your inner fenders very last, after fenders are installed. Just has always been easier for me that way.
Bart_Swisher is offline
post #7 of 18 (permalink) Old Oct 10th, 19, 12:20 PM
Take a good look at all the seam sealer, including under the windshield
dental picks and small wire brushes are your friend...
kolo is offline
post #8 of 18 (permalink) Old Oct 12th, 19, 12:40 PM
Greg
Assuming that the fenders are still on, I would put the inner fenders in before the engine.
A few years ago I started a project similar to yours. Just wanted to freshen up the engine bay. Thought that it would take me 4 months or less. After pulling the engine and transmission I decided that it wouldn't really be that much more work to lift the body up off of the frame so that I could clean up the frame. My 4 month project took 14 months, but was worth it.
Greg
Schwany and davidaugust like this.
My 68
and my 68
. In 1968 I got my
66 Chevelle SS. 30 years later, I got my
. Both Chevelles are in the same location.
Greg P is offline
post #9 of 18 (permalink) Old Oct 14th, 19, 6:38 PM
Hi Mario,
I'm replacing the motor in my 1971 Chevelle. First time I have attempted such a project. I have the old motor out and would like to clean and paint the engine bay. I could use some guidance in prepping and painting, such as type of paint, the components.
I'm also planning to replace the inner fender wells. Hoping someone can share their experience in choosing plastic or metal inner fender well replacements. I would like to purchase "direct fit" wells, if there is such a thing.
Jimmy George is offline
post #10 of 18 (permalink) Old Oct 20th, 19, 10:13 PM
I did it old school. Hand grinder and sand paper. Got rid of all rust then applied rust preventer then rattle canned the frame. As mentioned, I did all new brake lines and changed motor mounts from ABC to bbc and put in a 396. I installed everything before fenders finishing with radiator core support and wiring.
ID:	606042   Click image for larger version
1967 Chevelle
396 (.030)
Muncie M21, 3.90
acswimmer02 is offline
post #11 of 18 (permalink) Old Oct 20th, 19, 10:17 PM
Some more pictures.
ID:	606046   Click image for larger version
ID:	606048   Click image for larger version
ID:	606050   Click image for larger version
1967 Chevelle
396 (.030)
Muncie M21, 3.90
post #12 of 18 (permalink) Old Oct 21st, 19, 8:26 AM
Mr Bill
Mario,
When I did the engine and trans last year in my Wife's 84 Riviera I called a friend with a tow truck and we took it to the local DIY carwash. I spent about $15 with the engine degreaser and the high pressure spray but it was well worth it. 35 years worth of dirt etc came off very easily and I had very little else to do. It was well worth the tow bill and the carwash bill to get it spotless.
There is no way I could have done it that easily at home.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #13 of 18 (permalink) Old Oct 21st, 19, 12:13 PM
Greg
I concur. For rattle can painting under the hood I like the look of Eastwood's Underhood Black. However, that's a 1K paint, so I've switched to a 2K black that looks the same. Downside: more expensive and you need to use it within 24 hours after it is activated. Upside: more durable.
https://www.spraymax.com/en-us/produ...hot-rod-black/
Greg
My 68
and my 68
. In 1968 I got my
Greg P is offline
post #14 of 18 (permalink) Old Oct 21st, 19, 7:26 PM
Greg I see that site, but I don't see anywhere to buy the stuff. Where did you buy it? this is the first time I've a 2k product in a spray can.
post #15 of 18 (permalink) Old Oct 23rd, 19, 9:25 AM
Ron
It's on Amazon
bluemonday is offline
