Inner/Outer Wheel Well to Rocker Gap - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 2 (permalink) Old Sep 29th, 19, 4:59 PM Thread Starter
Ben
Anyone know if there is supposed to be an 1/8-1/4" gap around the outer wheel house to the rocker? The outer wheel well is tight and flush against the rocker flange on the inside of the rocker, facing the front of the vehicle. It appears to be factory because we found seam sealer in the rocker and this would probably prevent the wheel well from meet the rocker flushly. Can someone please look at there Chevelle and confirm the gap.
ID:	604426   Click image for larger version
BigBlockPyro is offline
post #2 of 2 (permalink) Old Oct 2nd, 19, 5:35 PM
Bart
Re: Inner/Outer Wheel Well to Rocker Gap
I don't remember if mine had a gap or not to be honest. I would pop the quarter panel back on and see how things look. The inner wheel well has to meet up correctly with the fender lip so I would check it first. The inner wheel house can be moved outward if needed.
Bart_Swisher is offline
