Rear window channel prep - Chevelle Tech
Body Shop Paint & Body Forum
  • 1 Post By BluesBoy721
post #1 of 7 (permalink) Old Sep 11th, 19, 12:15 PM Thread Starter
So the next part of my project has me repairing the rear window channel. There were rust holes in the pretty much expected areas: The lower corners of the channel, and I also had one in the left-middle. I've already gotten patches fabricated to replace those sections. However, the part that I'm wondering more about is the pitting from rust on the majority of the channel. At first I didn't think much of it, but I need to make sure: Is the scaling of the metal going to cause any issues in terms of sealing/adhesion? Overall, the metal seems to be pretty intact. I'd say it just looks worse than it actually is. I just figured I'd wire wheel the heck out of it and then chemically treat the metal, and then epoxy prime.
BluesBoy721 is online now
post #2 of 7 (permalink) Old Sep 11th, 19, 2:15 PM
Re: Rear window channel prep
If you haven't gotten all the patches made, Belden speed makes repair sections
70GS455 is offline
post #3 of 7 (permalink) Old Sep 11th, 19, 2:33 PM Thread Starter
Yea, I saw that from an another post. I was able to save the $80 for now and make the small patches myself. I'm just more curious if its necessary to replace the pitted sections which is almost the whole thing.
post #4 of 7 (permalink) Old Sep 13th, 19, 1:47 PM
Deon
I just did mine in small sections like your doing. I would say it matters just how deep the pits are. If you get them clean and shiny before epoxy I wouldn't think it matters as the window bond glue will fill in the imperfections.
I found that when I glued my back window in it got everywhere even wearing gloves.
72 Chevelle, 454, TH400, 3:73's
72SS454Chevelle is online now
post #5 of 7 (permalink) Old Dec 14th, 19, 1:20 AM Thread Starter
I finished this back in September, but I was able to get the metal stripped down as best I could and chemical treated whatever the wire wheel couldn't get, and custom patches made and installed. I'd say there's only a *minor* difference =P
ID:	610624   Click image for larger version
ID:	610626   Click image for larger version
ID:	610628   Click image for larger version
72SS454Chevelle likes this.
post #6 of 7 (permalink) Old Dec 14th, 19, 8:26 AM
I did a repair like that on the rear window of a '62 Nova. I sand blasted the pits, used rust converter spray, then filled with fiberglass filler. Never showed any problems after 14 years when I sold it. That car used a rubber seal not adhesive sealer. Several years after driving it on the street, I pulled the glass & rubber seal out and bolted in a Plexiglas window to lighten the car for drag racing. All of the paint was good as new under the rubber.
69SS454 is offline
post #7 of 7 (permalink) Old Dec 17th, 19, 6:25 AM
Deon
Looks good!
