Bury graphics and stripes in the clear coat - Chevelle Tech
Body Shop Paint & Body Forum
 2Likes
  • 1 Post By stanski
  • 1 Post By Blackhawk
post #1 of 7 (permalink) Old Sep 8th, 19, 11:05 PM Thread Starter
Stan
Doing some graphics and pinstripe accents on an upcoming paint job. Graphics are narrow sections of engine turned vinyl wrap and stripes will be painted base coat. I want these absolutely buried and the clear flat as water on a plate. I'm thinking 2 coats of clear, wet sand those areas smooth, then a couple more coats then wet sand and buff.
Even if the booth heat is cranked up, I figure at least 24 hours before flattening out the first round of clear and re-spraying the final coats. Would the entire car need to be scuffed before the second round of clear. I would think yes.
Capt Casey likes this.
stanski is offline
post #2 of 7 (permalink) Old Sep 9th, 19, 10:57 AM
Cody
Re: Bury graphics and stripes in the clear coat
How thick is the vinyl? 2 coats may not be enough to keep from breaking through the edge, especially if your first coat is lighter. 3 coats would probably be safer. Any chance of using a water slide decal instead so it's thinner?
Scuffing would be a good idea after 24 hours. You don't need to go crazy with it, a gray scuff pad works fine.
Bart_Swisher likes this.
1971 Monte Carlo
Blackhawk is offline
post #3 of 7 (permalink) Old Sep 9th, 19, 1:34 PM
I always worry about the graphics to clearcoat chemical reactions where the graphics shrivel up under the paint.
oldcutlass is offline
post #4 of 7 (permalink) Old Sep 9th, 19, 6:56 PM Thread Starter
Stan
The vinyl is 3 mil. I'm going to prep it with 2000 paper before applying.
stanski is offline
post #5 of 7 (permalink) Old Oct 2nd, 19, 4:47 PM
Bart
3 coats, wet sand, 3 more coats and you will be fine. Every Harley ever made that I have seen has vinyl graphics buried under the clear. You should have no issues.
Bart_Swisher is offline
post #6 of 7 (permalink) Old Oct 2nd, 19, 4:59 PM
Mark
I've done this on several cars in the past and have learned this. You need to put at least 3 coats of clear over the entire surface. The next step is to sand that surface with at least 800 grit paper to even things out. I suggest using the longest block you can find as this will produce the best results. This levels the entire surface quickly and leaves the surface with enough bite for the following clear coats. I usually wait 48 hours to begin sanding the initial clearcoat, but temperature is key here. I then follow up with 3 more coats of clear and depending how well the second round lays down, finish sanding usually starts with 1000,then 1500,2000,2500.It's not custom painting but custom sanding that makes a show car finish
modern malibu is offline
post #7 of 7 (permalink) Old Oct 3rd, 19, 11:10 AM Thread Starter
Stan
Thanks for the input, my painter was leaning towards 2 coats of clear on the initial, I will talk him into 3. Good reference to the new Harley's, never considered that, but I did notice a new Indian, had nice retro stripe accents that were likely vinyl drowned in clear.
I chose the engine turned vinyl, reminds me of a 64 Impala SS I used to own.
stanski is offline
