Hood pin holes in recent paint ? - Chevelle Tech
Body Shop Paint & Body Forum
 7Likes
  • 3 Post By Pete 67
  • 1 Post By Hotrodder000
  • 2 Post By DUTCH MAX HEADWORK
  • 1 Post By stanski
post #1 of 8 (permalink) Old Sep 6th, 19, 6:15 PM Thread Starter
Would I have a problem drilling holes in a newly painted hood ?
Slick87gn is offline
post #2 of 8 (permalink) Old Sep 6th, 19, 6:24 PM
Claude
Re: Hood pin holes in recent paint ?
You will have a problem if the drill bit slides off it's place while drilling! You'd definitely be safer by drilling them before painting the hood.
Good luck!
Claude.
1971 Chevelle SS
toofastforyou is offline
post #3 of 8 (permalink) Old Sep 6th, 19, 7:03 PM
This can be done....carefully. First, masking tape is your friend, use it a lot of it to protect the surrounding area. Use a center punch to mark your spot & then start with a very sharp 1/8" drill bit as a pilot hole. Then use a stepped drill bit to achieve the proper size hole. Use light pressure & let the drill do the work. You don't want to create an impression on the hood.
Luckily there is a stainless bezel for the outside of the hood in case you screw up with the drill, but if you start with a sharp bit, you should be ok.
71350SS, davewho1 and Hotrodder000 like this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #4 of 8 (permalink) Old Sep 6th, 19, 8:15 PM
I second the center punch. Use a somewhat small punch to start the whole. Keep the drill bit cool and let the drill do its job slowly like Pete said. Last time I did this I used painters tape around the area.
Pete 67 likes this.
If it's not broken, let's fix it till it is.
Hotrodder000 is offline
post #5 of 8 (permalink) Old Sep 7th, 19, 1:07 AM
Al
Don't forget to paint the hole so rust doesn't start there.
Pete 67 and 71350SS like this.
DUTCH MAX HEADWORK is offline
post #6 of 8 (permalink) Old Sep 7th, 19, 10:25 AM
Stan
Actually doing this on a newly painted hood is preferable to an older hood. If you ****** things up you still have the right paint for the re-paint job.
Pete 67 likes this.
stanski is offline
post #7 of 8 (permalink) Old Oct 2nd, 19, 4:50 PM
Bart
masking tape and drill slow, if you build up heat the paint will lift around the edges. As said, paint the edge of the hole when finished.
Bart_Swisher is offline
post #8 of 8 (permalink) Old Oct 2nd, 19, 7:19 PM Thread Starter
Job completed . Thanks guys.
