1967 Chevelle frame repair - Chevelle Tech
Body Shop Paint & Body Forum
 11Likes
  • 3 Post By Pete 67
  • 1 Post By Mikes64
  • 3 Post By Bronze68
  • 2 Post By Bonan73
  • 2 Post By RAIDER SS
post #1 of 10 (permalink) Old Sep 3rd, 19, 2:25 PM Thread Starter
I'm stripped my '67 down to the frame and found that 2 of the front body mount pockets are rotting out. I'm going to have the frame blasted and powder coated but need to fix this first. Looking for suggestions on the proper way to repair this. See the attached photo.
Bonan73 is offline
post #2 of 10 (permalink) Old Sep 3rd, 19, 2:45 PM
Re: 1967 Chevelle frame repair
This is actually a pretty easy fix. Someone sells thick flat washers with the correct ID size for the bushing to sit in.
You'll need to open up the area of the damage to the proper OD of the washer & weld it flush. Once it's ground & painted, nobody will ever know it was repaired.
davewho1, slowmo55ss and Bonan73 like this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #3 of 10 (permalink) Old Sep 3rd, 19, 4:08 PM
Michael
Fastenal sells the same washers for about a third of the price that some of the Chevelle suppliers, forgot the part numbers may need to do a little searching.
Bonan73 likes this.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #4 of 10 (permalink) Old Sep 3rd, 19, 6:36 PM Thread Starter
Thanks everyone!! I found the washer you suggested. Should be able to get that fixed quick and easy.
Bonan73 is offline
post #5 of 10 (permalink) Old Sep 3rd, 19, 9:15 PM
Most pros and hobbyists stock metal and don't need to buy repair kits. If subbing it out to a welder, they would have steel in stock. I make my own patches like many do in the restoration industry.
Raven1 is offline
post #6 of 10 (permalink) Old Sep 3rd, 19, 9:22 PM
Shops and non pros buy steel directly and pay less than a middle man charges.
Raven1 is offline
post #7 of 10 (permalink) Old Sep 3rd, 19, 9:28 PM
Folks are right, you can buy the specific washer inserts from UMI, or flat washers from the hardware store will work. I use both, depending upon the severity of surrounding rust and metal thickness. If the rust is serious around the hole, I have machined the larger hardware store washers to correct I.D. and whatever O.D I need to fully clear the rust.
Generally, it's pretty simple/quick.
I use a hole saw on a pneumatic drill. An electric or cordless drill will work, but they generally struggle on metal holes this size.
Weld a tab across the damaged hole, and take your time to locate the original center as best as possible. Drill a small pilot hole, and then go for it with the hole saw.
Below are some pictures. One is a smaller O.D. UMI washer (they laser cut them) and the other is a larger hardware store washer. I use a 2 3/8" hole saw for the UMI. I make the O.D. of the hardware store washers not only clear the rust, but accommodate a common hole saw size.
I weld them in with TIG, using about 95-100 amps. That seems to work the best for me to get full penetration without burning through. MAKE SURE THE METAL IS CLEAN BEFORE WELDING!
NOTE: the last thumbnail shows the underside of completed repair - it will look like it is not fully penetrated in the top of the picture. That is where the frame halves overlap from the assembly process, and the weld generally won't penetrate through both layers of frame material. You can see full penetration where it is only one layer of frame material.
ID:	602306   Click image for larger version
ID:	602308   Click image for larger version
ID:	602310   Click image for larger version
ID:	602314   Click image for larger version
71350SS, RAIDER SS and Bonan73 like this.
Bronze68 is online now
post #8 of 10 (permalink) Old Sep 6th, 19, 1:19 PM Thread Starter
Thanks everyone! I went ahead and got the washer from Fastenal since I just needed 2 ($5.31 total). It seems it will be way less time/work than fabbing these out from scratch. Thanks for the pics!!
davewho1 and Don B like this.
Bonan73 is offline
post #9 of 10 (permalink) Old Sep 7th, 19, 11:22 AM
Michael
You are correct, however in rural areas ain’t so easy, only one “metal shop” here and they know it.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #10 of 10 (permalink) Old Sep 7th, 19, 5:02 PM
David
What a great trick - thanx for sharing!
Hole saws work great as long as you know how to use them; slow speeds, and using a cutting oil. They will stay sharp and cut through steel again and again.
Pete 67 and Bonan73 like this.
66 Malibu......back to life with a 427 BB & 4 speed
RAIDER SS is online now
