quarter window trim - Chevelle Tech
Body Shop Paint & Body Forum
  • 1 Post By Pete 67
post #1 of 9 (permalink) Old Aug 13th, 19, 1:16 PM Thread Starter
quarter window trim
hi. anyone know how to get the trim off the quarter window of my 300? also,there is a big open gap at the bottom of the trim. should this be filled? thanks
Buncherman1! is offline
post #2 of 9 (permalink) Old Aug 13th, 19, 1:52 PM
Re: quarter window trim
What year are you working on?
davewho1 likes this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #3 of 9 (permalink) Old Aug 13th, 19, 3:46 PM Thread Starter
66
post #4 of 9 (permalink) Old Aug 13th, 19, 3:58 PM
Which trim are you referring to, the trim along the glass itself or the window fuzzie that is clipped on the quarter panel? Would help to see a pic of this gap you're talking about.
Trim on the glass taps off with a rubber mallet & a small block of wood. Be gentle.
The window fuzzies take patience to get off without distorting them. Use a tiny flat head screwdriver on the clips & the pop off one at a time. Start at each end & alternate side to side.
Pete 67 is offline
post #5 of 9 (permalink) Old Aug 13th, 19, 8:34 PM Thread Starter
i will post a pic tomorrow. thanks
post #6 of 9 (permalink) Old Aug 13th, 19, 8:49 PM Thread Starter
had time. the red trim is what i want to remove so i can get at the holes. there is a hole the same on the other side.looks like the trim is the way its supposed to be.cant imagine that gap is good
ID:	600486   Click image for larger version
post #7 of 9 (permalink) Old Aug 13th, 19, 9:34 PM
There are spring clips behind that holding it on. You can pop it off. The crappy fit at the bottom rear corner is common, although yours looks to be sticking out a little farther than most do. Once you clean up behind the trim and get the crud out from behind it, and freshen up the tightness of the clips, it might fit better. Good luck!
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #8 of 9 (permalink) Old Aug 14th, 19, 8:17 AM Thread Starter
thanks for the info. i see a clip under the trim but was scared of bending it. so it just pops off?looks like i have todays project
post #9 of 9 (permalink) Old Aug 14th, 19, 1:28 PM
Originally Posted by Buncherman1! View Post
thanks for the info. i see a clip under the trim but was scared of bending it. so it just pops off? looks like i have todays project
To remove that trim, those clips need to be treated like windshield molding clips. Much easier with the correct tool. This is the style I like...
Pete 67 is offline
