Rear glass recommendation needed - Page 2 - Chevelle Tech
Body Shop Paint & Body Forum
 14Likes
post #16 of 27 (permalink) Old Jun 21st, 19, 5:00 PM
Re: Rear glass recommendation needed
When you wire wheel, I would apply some epoxy primer to that bare metal, that windshield primer is not meant for bare metal.
1949 and 1972 chevy trucks
Pictures of my work
sevt_chevelle is offline
post #17 of 27 (permalink) Old Jun 21st, 19, 6:06 PM Thread Starter
Thanks. Any recommendation of a good primer I could use that I can brush onto the window channel?
lucifershammer is offline
post #18 of 27 (permalink) Old Jun 21st, 19, 8:55 PM
Randy
Steve, if your installer deal falls through, this guy supplies the materials and shows you how to do it yourself the correct way:
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #19 of 27 (permalink) Old Jun 27th, 19, 9:39 AM
Don't skimp on rivets / screws for the trim clips. Guy that installed my windows used cheap chinese crap. Rivet heads popped off from the tension of the trim and now they're leaking. Windshield channel is draining, but it's draining into the floorboard..
I'm debating on pulling the windshield, replacing all them, and possibly adding a smear of seam sealer under the clips when I install them.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #20 of 27 (permalink) Old Jun 27th, 19, 10:03 AM Thread Starter
All of my original trim clip studs are in place and in good shape.
I bought all new trim clips.
Right now, the glass company I found is scheduled out until July 9th. I've got an appointment then to drop the car and glass off (got the new glass already) and they will install it properly with urethane.
post #21 of 27 (permalink) Old Jun 30th, 19, 5:04 PM
According to a source here (El Paso area) butyl tape is still readily available. The butyl tape is apparently available in different thicknesses for the glass to achieve the proper height away from the pinch weld window channel. Personally have had several "jobs" done with urethane, (72 model) and invariably, the glass ends up too far recessed in the window opening for the stainless window surround trim to fit properly. Never been satisfied with a urethane job. In all fairness, one botched job was a body shop, the other job done by a non GM restoration individual. Neither were in a glass shop, able and willing to work on an older vehicle. Have seen so many botched urethane jobs on older cars, have to wonder if it is compatible with older vehicles. Will now need, at some point, to remove the urethaned in glass and redo with butyl tape. What a pain. Maybe urethane and butyl tape can be combined, have heard of that, also.
daveschevyparts is offline
post #22 of 27 (permalink) Old Jun 30th, 19, 5:13 PM Thread Starter
I could easily get the 5/16 butyl tape and do it myself. But, I've read and been told it is inferior to urethane. And based on the butyl tape that just came out, I can't say they are wrong.
The one downside I've heard about urethane is the window is in too low. The trim will still fit but there will be a gap between trim and glass.
I did ask if they will use a 5/16 foam damn and then urethane. Or somehow ensure the height is 5/16 so the trim will fit correctly. They said yes. I guess I will find out.
post #23 of 27 (permalink) Old Jun 30th, 19, 5:29 PM
Yes would be advisable to get some sort of assurance that the shop knows what it is doing. Mainly that the glass will not be too close to the pinch weld window channel.
post #24 of 27 (permalink) Old Jun 30th, 19, 6:09 PM Thread Starter
Agreed. The first thing I did was simply tell them that I had a '72 Chevelle that needed rear glas put in because it was leaking. Didn't lead the witness at all.
The guy seemed to know exactly what to do. Even said he could take the glass out for me and then I could take it away to have all the rust fixed lol.
I explained what it looked like in there, he said the old butyl had dried up and was leaking. He was right. He said he would reinstall with butyl or urethane whichever I preferred, but he prefers urethane. I mentioned I wanted to make sure the height was right and asked if they used a foam dam and urethane and he said yes.
I talked to him the other day to set up the appointment after I told him I got the window out. Told him I would clean up the rust and primer with some epoxy primer. He said that was perfect, he would then put urethane primer over that which is compatible with what the urethane company wants him to use. He is the guy who is actually going to install the glass.
He said he would get the height correct. I've got all new trim clips which will be installed when he gets the car. I'll leave the trim with him too and he can test fit it.
Like I said, we will see what happens. Hopefully he gets the height correct. He says he will. I'll make sure he knows it should be 5/16 high.
I would consider doing it myself with urethane. But I know I'll make a huge mess. This is one of the things I don't mind leaving to a professional. And he's the only glass installer that would touch my car in this area that I have found so far. So, not many choices.
LeoP likes this.
post #25 of 27 (permalink) Old Jun 30th, 19, 8:29 PM
Pete
I pulled my Rear Glass when i was putting in Quarter-panels .
After the paint was done I brought the car to a real glass shop that has been in business for 40 years.
Had them remove the front glass, (got the speech that it could break, but it leaked, so it was worth the risk) and put the rear glass back in.
Also handed them a bag of correct new molding clips and the original chrome molding that I hand polished. (The re-pop molding didn't fit/look right when i tried to test fit it)
They let me hang out and watch while 2 guys that knew what they were doing did the job using Urethane. The rear was ready, but after pulling the front glass they cleaned it up and used some kind of epoxy rust inhibitors and used little blocks to set the height. Looks perfect.
$150 per side. Well worth it.
LeoP likes this.
__________________________________________
1970-1 Chevelle (307ci w/PG) Now LS 6.0 w/4l60E
Progress Pics.
LS Swap
BigOiBoy is offline
post #26 of 27 (permalink) Old Jun 30th, 19, 11:31 PM
Pete
Besides, the breeze rolling through the car with no window is very refreshing.
Jeff, up north, depending on the month, that breeze can be more then "refreshing"
lucifershammer and Hotwire like this.
Progress Pics.
LS Swap
BigOiBoy is offline
post #27 of 27 (permalink) Old Jul 9th, 19, 2:51 PM Thread Starter
Just to follow up on this - got the glass in, and it looks great.
I cleaned up the window channel pinch weld with a wire wheel, epoxy primered it and touched up a few minor spots with touch up paint the other day.
Today, I put on all new trim clips and took it down to the glass shop. He took his time and did a good job with the foam dam, urethane primer and urethane. Trim sits nice, height of glass appears about right. He also said that it should not leak and I should have no problems - but, if I do, give him a call and he will take care of it.
I'm happy with the result, and happy with the smoke grey tinted glass (I think I made the right choice there.)
First picture is after cleaning up the channel, second is just now with the glass in.
Name:	Glass Out Prepped.jpg
ID:	597806   Click image for larger version
Pioneer4x4, Kopfjaeger and Hotwire like this.
