70 Malibu and Nu-Relics power window install - Chevelle Tech
Body Shop Paint & Body Forum
post #1 of 1 (permalink) Old Jun 9th, 19, 4:47 PM Thread Starter
Nick
Trying to not purchase the regulators and have to return them. Seems like the speakers are the big issue, but I have some other questions for their tech support that have not been answered. Here is what I wrote to them:
____________________________________
Any chance you folks have a link to a schematic for your ACI power window motors? Want to merge these motors into a classic restomod and I would like to be sure that I can use them before I order. I’m assuming at this point that the motor will operate on two input leads (pos/neg) with opposite polarity causing reverse motion. Is that correct?
Also before I order them, this is your item for the 70-72 Chevelle overlayed on a photo of the stock regulator; here’s a link: https://www.nu-relics.com/product-p/47000-400.htm. It says “left” (I assume drivers side) but making it mount correctly is not clear. If this is how it mounts (the OEM is shown in its mounted position), how does it bolt? Or does it require modification??? Or is there a PDF that answers all these questions?____________________________________
If any of you guys have answers to any of the questions, it will be much appreciated.
Here's a link to my 2014 Camaro SS donor to 70 Malibu restomod project:
Last edited by pcguy; Jun 9th, 19 at 4:51 PM. Reason: Photo did not insert - added
pcguy is offline
