Hood Hinge Nuts in Inner Fender - Chevelle Tech
Body Shop Paint & Body Forum
  • 1 Post By pnugene
post #1 of 10 (permalink) Old May 22nd, 19, 12:52 PM Thread Starter
One of the two nuts for the lower mount of the hood hinge to the driver's side inner fender of my 67 Chevelle broke. I need to find and replace the nut. It looks like a square nut and has a captured "washer" on the back. Obviously the nut is inserted from the inside of the fender.
Does anyone know what nut I need and where I can buy one? Does the nut need to be spot welded to the inner fender?
Nanny Blue is offline
post #2 of 10 (permalink) Old May 24th, 19, 9:11 PM
Randy
Re: Hood Hinge Nuts in Inner Fender
PM sent.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 10 (permalink) Old May 25th, 19, 8:03 AM Thread Starter
Originally Posted by pnugene View Post
PM sent.
Randy, messenger is giving me problems and does not seem to be sending.
Here is my reply:
Hey Bob, I have the fender nut you need. It's a square nut with a shoulder flange on the inside, pressed into place. You can probably re-install it from the front side with a 3/8 bolt through a socket to pull it into place.
I had a scrap 67 fender and that's how I pulled it from the backside. Send me your address and it's yours.
Randy.
Randy, thank you. If you get my reply more than once, messenger is being "difficult" this morning. Yes, that is the nut I need. Tell me what I owe you.
My address:
Bob Slaney
5912 Wood Stork Way
The Villages, FL 32163-0276
Home: 352-643-5422
Cell: 770-354-6668
Thanks again!
post #4 of 10 (permalink) Old May 25th, 19, 11:42 AM Thread Starter
THanks for the call this morning. I really am grateful to you for sending me the correct nut.
post #5 of 10 (permalink) Old May 25th, 19, 1:54 PM
Randy
No problem, glad to be of help.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #6 of 10 (permalink) Old May 25th, 19, 3:41 PM Thread Starter
My Chevelle:
Photographer had a pretty strong blue tint in this pic. My car is Nantucket Blue, not Marina Blue:
Missing nut on fender:
post #7 of 10 (permalink) Old May 25th, 19, 4:34 PM
Randy
Here in Alabama we would say that nut hole is a little wallered out, you may need to epoxy it into place until you tighten up the hinge.
Nanny Blue likes this.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #8 of 10 (permalink) Old May 25th, 19, 5:05 PM Thread Starter
I did gently hit is with a hammer and that flattened the "wallered" bit; however, I do intend to use some epoxy. I suspect that nut hole was a problem waiting to happen.
post #9 of 10 (permalink) Old May 25th, 19, 10:17 PM
Those are pierce nuts, and are on many other cars. I own a resto shop. Simply tack weld a nut using care. Good luck finding a shop that will not screw it up. I just restored a car and the nut was loose on an NOS fender. These types of things are normal if you've been doing this for decades as a profession..
Raven1 is offline
post #10 of 10 (permalink) Old May 26th, 19, 7:21 AM Thread Starter
I do have a local body shop but I doubt that they are as experienced as you re this little nut. I'll pass on your advice and thanks very much.
hood hinge recommendations? mb66l79 Body Shop 7 Jul 25th, 17 11:51 PM
What nuts to install '67 "CHEVELLE" hood emblem vikingshelmut Body Shop 2 Jul 15th, 17 2:18 PM
70 Hood and fender alignment hits firewall bluechevelless Body Shop 7 Apr 1st, 16 7:32 AM
"Basics of Basics" Hood spring installation or removal. MARTINSR Body Shop 34 Apr 29th, 14 10:55 PM
Hood To Fender Gap Issue/Hinge????? blm Body Shop 44 Apr 21st, 14 1:45 PM
