Body bolt welded to nut - Chevelle Tech
Body Shop Paint & Body Forum
 5Likes
  • 1 Post By BillK
  • 1 Post By ZEN357
  • 1 Post By Dean
  • 1 Post By ZEN357
  • 1 Post By kaljam
post #1 of 11 (permalink) Old May 20th, 19, 6:03 AM Thread Starter
Henrik
Hi,
Is this normal:
http://www.morsing.cc/photos/Cars/BigRed/Body_nut.jpg
(Sorry, I tried to insert the image but it just shows up as a blank line)
The tack weld actually goes on the bolt thread, if it's not clear. Not sure how to get that off...
It's the same on the other side.
Cheers
Henrik Morsing
'89 Volvo 240GLT B230E/AW70
'70 Chevrolet Chevelle Malibu "Big Red" 350/TH350/3.42 Posi, 60" 2.15s - [email protected]
- Restoration blog
Volvo240GLT is offline
post #2 of 11 (permalink) Old May 20th, 19, 8:07 AM
Re: Body bolt welded to nut
Originally Posted by Volvo240GLT View Post
Hi,
Is this normal:
(Sorry, I tried to insert the image but it just shows up as a blank line)...
I assume that is someone's home brew lock nut, just a guess.
And as for the picture, you can only insert an image from an HTTPS link, not HTTP.
Pioneer4x4 is offline
post #3 of 11 (permalink) Old May 20th, 19, 8:22 AM
Mr Bill
Looks like you have pretty good access. I would just take a die grinder and grind the weld off. If you have to just grind the nut in half. The body bolt can be replaced if it gets messed up too badly.
Volvo240GLT likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #4 of 11 (permalink) Old May 20th, 19, 8:40 AM Thread Starter
Henrik
Hi,
I'm not sure grinding the weld off you leave a clean enough thread to just un-screw it and I don't think there's access enough to cut the whole thing off. It might be easier to try and cut the head of the bolt underneath.
Cheers
Henrik Morsing
- Restoration blog
post #5 of 11 (permalink) Old May 20th, 19, 8:54 AM
That certainly is not from the factory!!!
ZEN357 is offline
post #6 of 11 (permalink) Old May 21st, 19, 8:58 AM
Can you get a dremel in there to grind off the weld?
ZEN357 is offline
post #7 of 11 (permalink) Old May 21st, 19, 9:16 AM Thread Starter
Henrik
Possibly, but as mentioned earlier, will it like the thread tidy enough to un-screw the bolt?
Cheers
Henrik Morsing
- Restoration blog
post #8 of 11 (permalink) Old May 21st, 19, 11:19 AM
How about cutting the head off of the bolt?
OR, You might try rotating the bolt around a little and cutting through the bolt, nut and weld.
I do it this way sometimes to cut a nut in half.
post #9 of 11 (permalink) Old May 22nd, 19, 10:00 AM
I'd give it a shot even if you cut the bolt off level with the top of the nut and get it off that way.
ZEN357 is offline
post #10 of 11 (permalink) Old May 22nd, 19, 1:35 PM
How about a cutting torch and put in the right hardware?
Pioneer4x4 likes this.
71 Chevelle
Mark Jones 454
Dynamic TH400
QP 9"
kaljam is offline
post #11 of 11 (permalink) Old May 22nd, 19, 1:53 PM
Yep, that is what I would do, stick a scrap of sheet metal as a shield, and burn away. I cut a lugnut off a stud in a recessed aluminum wheel, and only ruined the clear coat. You can get very precise with a nice "hot wrench".
Fisher Body sequence number double Check mymalibubu72 Tag Team 14 Mar 3rd, 19 1:18 PM
What rear end did I just buy? 10 bolt cover, 12 bolt ring gear 72ragtop Transmission & Driveline 7 Nov 14th, 14 4:31 PM
Rod bolt strength, what do we REALLY NEED? 540 RAT Performance 25 Mar 3rd, 13 10:55 PM
hardware- nut, bolt, screw sizes psi3000 Restoration Corner 13 Mar 2nd, 13 3:37 AM
