dash cover finish recommendations - Chevelle Tech
Body Shop Paint & Body Forum
 4Likes
  • 1 Post By pcguy
  • 1 Post By pcguy
  • 2 Post By pcguy
post #1 of 11 (permalink) Old Apr 29th, 19, 11:51 AM Thread Starter
Nick
Have been tied up with lots of health and home maintenance stuff and haven't made much progress, but now that taxes are behind us and the weather is a bit warmer, I'm back at my restomod project (link below).
The dash cover is a very complicated part of the project -- 5 inches of the leading edge of the plastic and all the accompanying structure were removed/rerouted. That combined with the repair of the airbag & HUD openings and the proper method of finishing final surface has me writing this thread so that I get all the opinions before I f this up... LOL
As you can see in the last photo, I have figured out how to weld the plastic (TPE, TPE & TPO are now considered the same??), well kind of anyway; it will look better when sanded.
Was thinking that after I get the top and bottom structurally prepared that I would prime and do a flat black stipple to somewhat match the rest of the dash and door panels. My test of this looked pretty good, but I also have checked out having a leather wrap.
Here are some pics and look forward to your comments, opinions and of course, criticisms.
Nick
ID:	592624   Click image for larger version
ID:	592626   Click image for larger version
deserttaco likes this.
Here's a link to my 2014 Camaro SS donor to 70 Malibu restomod project:
pcguy is offline
post #2 of 11 (permalink) Old Apr 29th, 19, 11:59 AM Thread Starter
Nick
Re: dash cover finish recommendations
Here's one more pic of the now contoured filler piece to match the A-pillar (also modified to support the new dash contour). All tacked in with my new found welding technique. HAHA
Nick
123pugsy likes this.
pcguy is offline
post #3 of 11 (permalink) Old Apr 29th, 19, 12:34 PM
Pugsy
Good stuff. What is this welding technique you speak of?
123pugsy is offline
post #4 of 11 (permalink) Old Apr 29th, 19, 2:20 PM Thread Starter
Nick
All of my searching on this lead me to ideas and methods that most of the plastic bumpers, door panels and dash covers can be welded in a variety of ways -- from the fairly expensive fusion air blast process to the cheap Harbor Freight glorified soldering gun (which is what I used).
Here’s a link: https://www.harborfreight.com/80-watt-iron-plastic-welding-kit-60662.html
and a search link for similar stuff: https://www.harborfreight.com/catalogsearch/result/index/?dir=asc&order=EAScore%2Cf%2CEAFeatured+Weight%2Cf %2CSale+Rank%2Cf&q=plastic+weld
Here's a link to some YouTube videos:
And a link to a product use page -- not what I used:
https://www.polyvance.com/Textured-Plastic-Bumper-Repair?p=69
Another couple of links to YouTube searches on dash repair and welding TPO:
https://www.youtube.com/results?search_query=epoxy+dash+repair
https://www.youtube.com/results?search_query=welding+plastic+with+solderin g+iron
And a good one for bumper repair, but the same process for dash, etc...
123pugsy and mymalibubu72 like this.
pcguy is offline
post #5 of 11 (permalink) Old Apr 29th, 19, 9:18 PM
Pugsy
Good stuff.
Thanks for the links.
123pugsy is offline
post #6 of 11 (permalink) Old May 24th, 19, 10:23 AM Thread Starter
Nick
Thought you might like to hear about some discoveries I made in my attempts to solidify a design for the door panel conversion and the finish of dash cover.
First of all, have not been able to find a full service interior shop that is willing to do any kind of plastic or fiberglass fabrication. Even one guy who bills himself as someone that does custom dashes said he limits his work to simple projects. And one other guy who bills himself as a plastic welder (even has his business card passed out by the local Tap Plastics shop) was too busy to even do a test on the type of plastic involved in my project.
FTR, most interior plastic parts in GM cars (and maybe others) is called thermoplastic olefin (TPO). The TPO reference is found on the inside of the parts next to the part number as part of the casting.
Turns out that Tap Plastics sells varying thicknesses of ABS in sheet form and that ABS and TPO both respond really well to plastic welding and to the application of a particular brand of superglue - DURO, which I believe is made by Loctite.
So I bought some 3/32" ABS for the new stock on the door panels and I am gluing and welding away on the parts that will be mechanically fastened to the panels after the application of the leather.
Some bondo and fiberglass at the end and some textured paint. If the end result does not look like what I want, I'll have the fabbed parts leather wrapped when the rest of the interior is done.
Looks like I may have to get into someone's cue because these guys are months out for a full interior. Just have not found the right company. Would like to know of any recommended shop that is in the SF North Bay.
Nick
ID:	594250   Click image for larger version
ID:	594252   Click image for larger version
pcguy is offline
post #7 of 11 (permalink) Old May 25th, 19, 12:20 AM
terry
I used to be a plastic welder in the past. If you just seam the joints, it isn't very strong. You need to float the seams on the back with some material with the welder you use. The one like in the video, ( I didn't look at it) uses filler rods, or you can use a (mucho bucks) extrusion type welder. It will look better if you have it wrapped, as it is almost impossible to get a matching finish from the grain of the panel and the prepped seam...
mytmouz is offline
post #8 of 11 (permalink) Old May 30th, 19, 5:27 PM Thread Starter
Nick
Design and plan as you go has a lot of drawbacks, especially if you want the door panel to match the ends of the dash with that 1/4" gap in between when the door is closed. Getting close to having a finished panel that will make the passenger side a whole lot simpler. Here are some pics:
ID:	594744   Click image for larger version
ID:	594746   Click image for larger version
ID:	594748   Click image for larger version
pcguy is offline
post #9 of 11 (permalink) Old Jun 9th, 19, 4:33 PM Thread Starter
Nick
Really hard to get to the end of this panel. Here are a couple of pics with the armrest/controls re-fabbed. The second pic is what it looks like when you apply wax paper to the fresh resin/fiberglass. Note that the mirror controls got moved.
Having real issues with the speaker location and how the as yet purchased power regulator may interfere with its protrusion. Will start a new thread and post a link here.
Nick
ID:	595434   Click image for larger version
pcguy is offline
post #10 of 11 (permalink) Old Jun 9th, 19, 4:49 PM Thread Starter
Nick
Here's the other thread:
https://www.chevelles.com/forums/12-...l#post11092038
pcguy is offline
post #11 of 11 (permalink) Old Jun 9th, 19, 6:11 PM
Terry
Going to be pretty sweet when it's done , Nick. Terry
68-13427 is offline
In-depth review of Indoor Bubble Car Cover by CarCapsule at CARiD.com Carid CARiD.com 1 Mar 6th, 19 9:16 AM
1970 Chevelle SS Lower Dash Panel Restoration jjr158 Interiors 10 Nov 10th, 16 12:34 PM
Correct dash pad for a 66 chevelle? stallonepanerai Interiors 4 Jun 9th, 16 11:54 AM
65 SS Interior "A" pillar color Dale H Body Shop 7 May 13th, 16 2:50 PM
Dash Conversion from sweep to SS gauge package sped01 Interiors 9 Mar 28th, 14 2:30 PM
