Best plastic inner fenders? - Chevelle Tech
Body Shop Paint & Body Forum
 2Likes
post #1 of 30 (permalink) Old Mar 21st, 19, 10:26 PM Thread Starter
My OEM inner fenders are shot, so I need new ones. Who makes the best plastic inner fenders for 71 Chevelles? I have an SS454 if that matters at all.
-SS454- is online now
post #2 of 30 (permalink) Old Mar 22nd, 19, 9:41 AM
Re: Best plastic inner fenders?
On my one owner 70 LS-5/ M-22 (Tlr. Queen) I had plastic inner fenders that were stamped " MADE IN CANADA ". I tried other plastic inners. Replacements from the dealership, The ones with a million numbers near the front of the inner fender. They should have a green " Mr. YUCK " sticker on them.
I bought some Reproduction inners,,,, METAL. The reproduction CHEVELLE inner fenders also fit, ALL G.M. products from 1928 to the 2019 Silverados. They also fit a 1949 Hudson.
YES, They will fit and look very nice. " WITH SOME WORK ".
If possible???????? Find a set of Org. 1970 metal inners and go in that direction.
When I built my 1971 Driver Nomad Sta. Wgn. I was going to remove the front inners and re/drill (for lights) and install them in my trailer Queen.
WHY?...... They fit and look just wonderful in my wagon. Its the same old story " Original Parts Fit ".............
Robinls5 is offline
post #3 of 30 (permalink) Old Mar 22nd, 19, 3:47 PM Thread Starter
I definitely have no desire to go with metal fenders.
So basically no reproduction fenders fit worth a damn?
post #4 of 30 (permalink) Old Mar 27th, 19, 11:03 AM Thread Starter
Has anyone bought plastic fenders?
post #5 of 30 (permalink) Old Mar 27th, 19, 3:20 PM
Shane
Nope. I went with metal. Never go plastic again.
1969 chevelle
fishhead is offline
post #6 of 30 (permalink) Old Mar 27th, 19, 8:31 PM Thread Starter
you had plastic and they cracked? Or was it some other reason?
post #7 of 30 (permalink) Old Mar 27th, 19, 9:23 PM
I installed steel fender skirts on my Monte. I didn't have to modify a single hole. It was a bear of a job though, I did it alone.
Same here. I believe plastic fender skirts on these cars will crack if the car is driven. Plastic does flex and if you're in a cold area, temperature swing cycles makes it brittle. My car had plastic GM skirts purchased in the 1980's. Both sides were cracked pretty good.
Although I have no proof, I feel steel fender skirts make the nose of the car a little more solid.
fishhead likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #8 of 30 (permalink) Old Mar 27th, 19, 9:25 PM Thread Starter
I believe the fenders could make the front end more solid.
Another option is carbon fiber... only $1800+
post #9 of 30 (permalink) Old Mar 27th, 19, 9:26 PM
Correction: I couldn't find a battery tray that had holes that matched the holes in the right skirt. I don't know if the problem was the skirt or the tray. And the holes for the parking light harness pass-through isn't there, but I think only Montys need them.
How may I help you?
1999 Trans Am-500hp
post #10 of 30 (permalink) Old Mar 28th, 19, 4:05 AM
Shane
I agree with Paul.
My plastics cracked.
You can paint the metal much easier than the plastics also.
1969 chevelle
fishhead is offline
post #11 of 30 (permalink) Old Mar 28th, 19, 9:39 AM
Bryan
Honest question. What would be the advantage of using plastic inner fenders? I'd imagine there is a small amount of weight you could shave off the car, but I'd also imagine this would only matter if you race competitively.
Also, I know this doesn't answer your original question, but I installed AMD inner fenders on my 66, with zero modifications needed to get them to fit.
'66 SS Clone
Fast Burn 385hp Crate 350 (for now)
Muncie M20 & 3.42 Posi
UMI Stage 2 Suspension all around
bry66 is offline
post #12 of 30 (permalink) Old Mar 28th, 19, 11:30 AM Thread Starter
It's all about weight. While not competitive racing at this point, I do track the car and the weight is a bad location. Frontward and outward. Plastic fenders are 5.5 lbs each.
post #13 of 30 (permalink) Old Mar 28th, 19, 12:21 PM
It's all about weight. <edit-delete> Plastic fenders are 5.5 lbs each.
and how much do the steel inner fenders weigh?
zookpr is offline
post #14 of 30 (permalink) Old Mar 28th, 19, 1:44 PM Thread Starter
I would love to know.
post #15 of 30 (permalink) Old Mar 28th, 19, 2:58 PM
Shane
The shipping weight of a metal inner is 22lbs. The shipping weight of a plastic is 20 lbs.
With that said, I dont remember much of a difference in weight when I changed mine.
The metal is thin, the plastic is much thicker.
AMD shows plastic fender at 16 pounds, metal at 22. I do not know if that is shipping weight.
1969 chevelle
fishhead is offline
Plastic inner fenders 70CHEVELLE396 Body Shop 10 Dec 17th, 15 3:19 PM
Repro inner fenders, Plastic or Steel? freewaydave Body Shop 6 Jul 17th, 13 3:53 PM
Plastic Inner Fenders (front) and Rear Defogger options mcfly 1999 -- 5 Oct 28th, 99 3:53 PM
