Need J-21550 door adjustment wrench or info - Chevelle Tech
Body Shop Paint & Body Forum
 5Likes
  • 1 Post By sevt_chevelle
  • 1 Post By 67_LS1
  • 1 Post By TechNova
  • 1 Post By 67_LS1
  • 1 Post By Blown1932
post #1 of 15 (permalink) Old Feb 19th, 19, 9:39 PM Thread Starter
Dennis
Does anyone have a J-21550 door adjustment wrench for early Chevelles? It was made by Kent-Moore and was a GM speciality tool.
If someone does, could I possibly get some dimensions from it? I would like to build a wrench of my own.
Maybe a tracing of the curved sections and offset info for the box ends?
Thanks,
Dennis
67_LS1 is offline
post #2 of 15 (permalink) Old Feb 19th, 19, 11:16 PM
Allen
Re: Need J-21550 door adjustment wrench or info
I happen to have 2 of them Likely won't be able to do anything until tomorrow but I can take a photo with a ruler if that would help
Blown1932 is offline
post #3 of 15 (permalink) Old Feb 20th, 19, 1:14 AM Thread Starter
Dennis
Or....I could possibly purchase one from you?? Or rent? Or borrow?
Seriously, a pic with a ruler could work.
Total length -
Total width - ( standing on edge with one box end on the table )
Box head offset - ( a side view of the ends )
I appreciate anything you can send me.
Dennis
67_LS1 is offline
post #4 of 15 (permalink) Old Feb 20th, 19, 6:32 PM
What makes it so special?
So after googling for about 1 minute, it's nothing more then a "S" wrench. One can buy a 5pc s wrench from sunex for around 25-30 bucks.
I've never needed such a wrench removing the thousands of doors I've done doing collision and restoration work.
davewho1 likes this.
1949 and 1972 chevy trucks
Pictures of my work
sevt_chevelle is offline
post #5 of 15 (permalink) Old Feb 20th, 19, 6:47 PM Thread Starter
Dennis
Its bent and offset in such a way that you can loosen the door hinge bolts from the A pillar without loosening or removing the front fender. Great for when you need to loosen the hinges up enough for door adjustments.
I would like to buy, rent, borrow one so I can fix my door issue and also use it as a model to build a duplicate.
There were others like it bent in other shapes for other model car doors but this one is socific to Chevelles.
67_LS1 is offline
post #6 of 15 (permalink) Old Feb 20th, 19, 7:04 PM Thread Starter
Dennis
Here is a pic....
67_LS1 is offline
post #7 of 15 (permalink) Old Feb 20th, 19, 7:23 PM
And another:
Name:	Kent Moore J-21550 K M tool for door hinge bolts.jpg
David
davewho1 is offline
post #8 of 15 (permalink) Old Feb 20th, 19, 8:34 PM
I used gear wrench swivel heads with a shorty socket. Works great.
(this is what I used)
https://www.chevelles.com/forums/att...p;d=1492647689
Loosen all the hinge bolts except one when adjusting. Leave lower bolt if you want to snug up top of door, and leave the upper bolt if you want to snug up lower edge of door.
Stickman is offline
post #9 of 15 (permalink) Old Feb 20th, 19, 9:48 PM
Allen
Total length -
Dennis
I paid 25 for the last one, if you want it for 25 that would work.
post #10 of 15 (permalink) Old Feb 20th, 19, 9:56 PM
Greg
I have 2 or 3 different ones I used to use a lot to adjust the hinge to cowl bolts. 2 door cars would have sag issues, We go a lot of farm trucks that would need adjust with or without a hinge rebuild. The offset makes it special.
71 Malibu
Asst Novas
TechNova is offline
post #11 of 15 (permalink) Old Feb 20th, 19, 9:59 PM
Greg
Originally Posted by davewho1 View Post
And another:
There is another that looks like a socket on each end rather than a box end wrench.
I have not been able to find one like it, I used to borrow it a lot from a coworker.
71 Malibu
Asst Novas
TechNova is offline
post #12 of 15 (permalink) Old Feb 20th, 19, 11:20 PM Thread Starter
Dennis
Ill take it for $25. That will save me a bunch of homework and welding.
I will PM you for the details.
Thanks,
Dennis
Freddy Mercado likes this.
67_LS1 is offline
post #13 of 15 (permalink) Old Feb 21st, 19, 12:00 PM
Donald
Does any one have one for a 66 with flush mount Phillips head bolt
donald d locklear is offline
post #14 of 15 (permalink) Old Feb 21st, 19, 2:06 PM
Pat
I made one with a socket and cut off the tip of a BIG screwdriver. welded tip into socket. Biggest problem is finding big enough tip which I think is #4.
myrusty66 is offline
post #15 of 15 (permalink) Old Feb 21st, 19, 11:10 PM
Allen
Photos
ID:	587030   Click image for larger version
Holly 300-19 intake info crazychevelle Engine 4 Nov 27th, 13 9:19 PM
Chevelle car show info please... toofastforyou Chevelle Tech 11 Nov 4th, 13 5:27 PM
Moving to California, looking for info on smog/registration bad.samaritan Chevelle Tech 30 Oct 19th, 13 1:30 AM
Driveshaft Yoke Replacement Info blm Transmission & Driveline 2 Jan 28th, 13 8:36 PM
Mallory unilite distributor info needed Kit 1999 -- 2 Jun 4th, 99 7:16 PM
