65 chevelle headlight buckets - Chevelle Tech
Body Shop Paint & Body Forum
  • 1 Post By RichardB
post #1 of 10 (permalink) Old Jun 15th, 18, 5:56 PM Thread Starter
hey doing frame up on 65 chevelle and now can't get headlights to sit level.They seem to go up on the outside edges.Using original frame body,fenders,radiator support and it all fit good before tear down.Put new body mounts in and already trimmed them down at firewall but still seems fenders are to high in front but door gaps are nice?
71 goldmyn is offline
post #2 of 10 (permalink) Old Jun 15th, 18, 8:06 PM
Verle
Re: 65 chevelle headlight buckets
Post some pictures.
Verle
Tulsa, Ok
Verle is offline
post #3 of 10 (permalink) Old Jun 18th, 18, 9:49 AM Thread Starter
pics of 65 chevelle headlight brackets
ID:	565257   Click image for larger version
post #4 of 10 (permalink) Old Jun 18th, 18, 2:49 PM
If they're similar to '66, they don't fit universally in each hole - each bucket goes in a specific hole, otherwise they are cattywampus.
For reference:
https://www.chevelles.com/forums/35-r...-sequence.html
@jeffschevelle ?
David
davewho1 is offline
post #5 of 10 (permalink) Old Jun 18th, 18, 9:29 PM
Richard
David is right. They do go into specific hole. They are also numbered. I can't tell you what number off the top of my head but if they don't look right, switch them around. I can't tell from the pictures exactly what your talking about.
Richard
davewho1 likes this.
65 Chevelle SS Convertible 350 4 speed Muncie...hopefully complete in another year or so
65 Chevelle SS hardtop 396, 4 speed
65 Chevelle Malibu Convertible, 350/TH350
64 Chevelle Malibu 2dr hardtop
64 Chevelle SS, 350/450hp, Muncie M21
RichardB is offline
post #6 of 10 (permalink) Old Jun 19th, 18, 1:26 PM Thread Starter
the 65 chevelle has headlight boxes or brackets that mount to the radiator support and they are sitting at slight angle.They also bolt to the fender lip on the front
post #7 of 10 (permalink) Old Jun 19th, 18, 7:58 PM
Are you aware that if you turn the adjuster screws you can move the headlights a long way in any direction (L, R, up or down) ?
jeffschevelle is offline
post #8 of 10 (permalink) Old Jun 20th, 18, 10:42 AM Thread Starter
yep aware of that but this is the bracket that holds the headlight assembly seems to go uphill on outside edge
post #9 of 10 (permalink) Old Jun 20th, 18, 7:37 PM
They are left and right specific. Maybe you have them mounted backwards? But if they are lining up with the holes in the fenders (which appears to be the case in your picture, where the large Philips head screws are), then probably not.
post #10 of 10 (permalink) Old Jun 21st, 18, 2:55 PM Thread Starter
No all the bolts line up but the fenders in general have to come down on the outside otherwise the headlight bezels and eyebrow mouldings will tilt slightly upward on outside. But with that being said gaps door to fender are good??When I push down I can get fender down but then bulges out slightly behind tire.
This Thread is more than 423 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
