'66 Bottom door drainage slot seals? - Chevelle Tech
Body Shop Paint & Body Forum
 2Likes
  • 1 Post By cheveslakr
  • 1 Post By jeffschevelle
post #1 of 13 (permalink) Old Jun 10th, 18, 9:48 PM Thread Starter
Mark
I'm working on a 66. The assembly manual shows the bottom door slot seals installed inside the door shell to keep the "dust and cold air out". Will these still allow any water inside the door to drain and dry-out or are you better off not installing the seals and leaving the slots open?
Thanks for any thoughts.
Mark
Mark
66 SS
berg1954 is offline
post #2 of 13 (permalink) Old Jun 10th, 18, 11:50 PM
Re: '66 Bottom door drainage slot seals?
I wasn't aware there were any.
David
davewho1 is offline
post #3 of 13 (permalink) Old Jun 11th, 18, 8:19 AM
Don
They are designed to allow water to drain,I got replacement's for my "66" ,I believe they came from Steele Rubber Products,they weren't listed for Chevelle. If I remember correctly I called them,they were listed for Old's-Buick but they worked.
Don B is online now
post #4 of 13 (permalink) Old Jun 11th, 18, 9:52 AM Thread Starter
Mark
I got mine from OPG, those little buggers cost more that you'd think.
Don, did you install inside the doors and does the water still drain out ok?
Mark
66 SS
berg1954 is offline
post #5 of 13 (permalink) Old Jun 12th, 18, 8:19 AM
Don
Had to install from inside the door,don't know if the water would drain or not,I clean the car with waterless products,and so far has not been in the rain.
Don B is online now
post #6 of 13 (permalink) Old Jun 12th, 18, 10:36 AM
jerry
I've never seen a door plug in that slot on any early chevelle. Were they installed originally? Don't see the point of plugging a drain hole where the door constantly sees water flow....at least on a production car.
davewho1 likes this.
cheveslakr is online now
post #7 of 13 (permalink) Old Jun 12th, 18, 12:12 PM
Its not a tight seal. The ones on my Elco and on the GTO I owned previously were mounted from the outside. This allows any water that enters the door to drain out and at the same time keeps dust and dirt inside the door to a minimum.
From the 68 Fisher Body manual, apparently not for Chevelles.
ID:	563505   Click image for larger version
ID:	563513   Click image for larger version
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #8 of 13 (permalink) Old Jun 12th, 18, 12:24 PM
Keith
Any one got a picture or link to one
Maryland Chevelle Club #682
keithb is online now
post #9 of 13 (permalink) Old Jun 12th, 18, 1:46 PM
@jeffschevelle ?
David
davewho1 is offline
post #10 of 13 (permalink) Old Jun 12th, 18, 3:36 PM Thread Starter
Mark
That's interesting, Ed, I agree with you and was planning to install them from the outside to insure that the water will drain out, as your details show, but my 66 Fisher body manual shows them installed from the inside.
I'm going to install from the outside.
Thanks to all for the feedback.
Mark
Name:	Bottom door slot seals.jpg
Mark
66 SS
berg1954 is offline
post #11 of 13 (permalink) Old Jun 12th, 18, 6:44 PM
They did not come on 64-67 Chevelles. That was just for the more luxurious Buick and Olds models. Not sure about Pontiacs. But it is certainly fine to add them if you think it will make the car quieter (but I really doubt it will make any noticeable difference).
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #12 of 13 (permalink) Old Jun 12th, 18, 11:01 PM
my 66 had em,and they were from the outside.mine is an early kansas car.i also have a full length one piece rock shield on the back bumper.
cherokeepeople is offline
post #13 of 13 (permalink) Old Jun 26th, 18, 5:28 PM
16000 series chevys, all olds, buicks, cads and some Pontiacs and no mention of chevelle series According to ED's book. someone at the fisher plant may have incorrectly installed them.
Jim_66SS is offline
This Thread is more than 418 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
