1966, lower windshield repair or replace... - Chevelle Tech
Body Shop Paint & Body Forum
 6Likes
post #1 of 33 (permalink) Old Mar 6th, 18, 7:27 PM Thread Starter
Well,
My '66 "California" car is nice just about everywhere, except for the lower windshield channel... The exterior portion is okay, and the front of the glass looks fine, but there are some holes in front of the glass...
Debating whether to patch or just replace the entire piece, but then that leads me to other questions...
I have found quite a few different anels offered, and I am not sure which I will need...
What is available?
I have seen the exterior panel with the integral windshield channel, as well as the front of dash repair panel (and even a complete top of dash panel)... I have also seen some companies selling a "brace", but their pictures suck. it looks almost like the exterior piece, but why offer two different parts for the same panel?
One of these suppliers was Sherman: They offer a 706-43A and a 706-43T, similar prices, but descriptions are sparse... they offer a #706-43 that appears to be the front edge of the dash...
NPD also offers two different part numbers that appear to be the same panel, and has both a US-made repro of the exterior panel, and what appears to be a foreign (waiting for confirmation, but one says US-made, while the other doesn't mention it)...
I found OPGI and AMD both offer the "exterior" panels as well...
So, any preference?
I am leaning away from OPGI, because Summit says they won't ship until sometime in April, and I have had issues with OPGI and backorders over the years... I have the Sherman on the way, but I could easily order the AMD through Summit (in stock)...
NPD has usually been great service, but I want the closest fit, since this will be my first exterior body panel...
Car is already disassembled, so it looks like I only need to remove the A-pillar covers (the windshield is loose, but not quite out yet)... Complete interior is out, as well as the engine and front sheet metal...
From what I could gather, this panel is spot welded to the front of the dash. and maybe the ends (under the A-pillars) are also spot welded. Is it welded anywhere else?
I know rust hides everywhere, but I am hoping the front of dash panel will be okay, as the holes aren't too bad...
The actually exterior body panel looks great, with the rust confined to the bottom of the channel, so I had considered "patching" (even had a Sherman panel on the way)... But I figured it may be harder to do all that cutting, welding and grinding down in the channel, as opposed to just replacing the entire piece... Use a spot-weld cutter to remove the spot weld?
Drill some holes for new "plug" welds?
weld-thru primer? any other "paint"?
seam sealer after its all back in?
Trim studs? I see AMK sells screw posts, and Belden Speed and Engineering sells screws OR pip-rivet trim studs... Preference? Not looking for concours, just functional...
A-Body Window Trim Clip Stud Options - Belden Speed & Engineering - window channel rust patch panels, chevelle, rust repair, patch panels, GM a body repair
I tried to remove the windshield, its only stuck along the top edge, but I misplaced my windshield tool...
I guess I should get that glass out, and grind/wire wheel the channel to actually see the extent of the rust...
Any suggestions/tips/hints would be great...
TC #1366
Sold
Sold
1966_L78 is offline
post #2 of 33 (permalink) Old Mar 6th, 18, 8:30 PM
terry
Re: 1966, lower windshield repair or replace...
I replaced the entire upper dash piece using an AMD part. I also replaced the outer piece as well. Really easy, and didn't take long...
mytmouz is offline
post #3 of 33 (permalink) Old Mar 6th, 18, 9:54 PM
i also just replaced the dash and windshield channel/front trim.the A pillar covers are brazed along the roof line so best to not take them off,but if you do the windshield channel,they do need to raise.there are 2 screws under the fender and 2 that are in the channel.i got a panel don't remember who made it but it came unpainted.it did not fit to save it's a$$.so ordered an amd and it fit light years better,but fit it to the vent panel in front of it before putting it on.and test fit the windshield BEFORE you do any welding.
cherokeepeople is offline
post #4 of 33 (permalink) Old Mar 6th, 18, 11:19 PM
David
I hate to say it, Tony, but don't be surprised to find more rust on your dash top than what you expect. I had visions of replacing only the exterior windshield channel and a dash top repair panel. After getting into it - I found the dash top had more rust on it than the width of the repair panel, so I ended up changing the entire dash top.
It didn't take a tremendous amount of paint stripping in this area to expose the rust as seen in the attached picture. The exterior channel came from Classic Muscle (made in USA piece), and the dash top came from AMD, as I did not find a entire dash top made in USA.
As you can see, I punched holes in the pieces so I could plug weld them in.
Sorry my pictures rotated on me. I don't know how to correct it when that happens.
ID:	531089   Click image for larger version
ID:	531097   Click image for larger version
66 Malibu......back to life, now with a 427 BB & 4 speed
RAIDER SS is offline
post #5 of 33 (permalink) Old Mar 7th, 18, 2:15 AM Thread Starter
Thanks, great pictures...
So, that "outer" panel, its ONLY spot welded to the area where the trim studs go? Since you didn't remove the A-pillar covers all the way, I'll assume that means that panel isn't welded under the covers...
Yeah, looking at the dash tonight (through the dirty window), there may be a few spots of rust starting on the dash itself...
Ironic, ALL of the rust through spots are in areas where the inner cowl has indentations (so that the rusted piece is only rusted where there is NO metal sandwiched below... And the bottom, where its open to the air is actually in the interior of the car...
If need be, I'll buy the complete dash top. Its more money, but a lot less work than trying to align/trim/weld/grind all the way across the dash just to replace that front piece...
TC #1366
Sold
Sold
1966_L78 is offline
post #6 of 33 (permalink) Old Mar 7th, 18, 2:19 AM Thread Starter
Thanks...
TC #1366
Sold
Sold
1966_L78 is offline
post #7 of 33 (permalink) Old Mar 7th, 18, 9:19 AM
David
The "outer" panel is welded to it's underneath metal structure (where I plug welded) and to the dash top itself. You can remove the exposed a-pillar retaining screws and carefully pivot the a-pillar cover out of the way for installation. You can see how the a-pillar cover overlaps the "outer" panel in one of the pix. IIRC, The a-pillar cover has no welds holding it on, but there was a ton of putty underneath it at the top and the bottom of the cover for waterproofing (FYI - see attached pix for all the screws on the door jamb side of the a-pillar cover. You only need to remove these if you eventually remove the cover))
I totally agree that trying to weld on a replacement repair piece to the dash top would have been way more work than just replacing the entire dash top. That kinda repair job would have been a real pain in the ars to do!
I attached a pix to show how I started to drill out the spotwelds on the original "outer" piece. Lucky for me, the underneath metal was in great shape, so welding the new piece back onto it was good to go.
I also attached a pix to show one end corner of the "outer" piece and the dash after welding and grinding, and after I picked out most of the putty underneath the a-pillar cover. There is a lot going on in that intersection!
Because of the rust (therefore water leaks) on the underside of this area - I found that everything underneath the dash top was FILTHY. The instrument cluster, the wiring harness, the pedal bracket, heater box.....everything. You get the idea. Be prepared for some extra cleanup!
ID:	531193   Click image for larger version
ID:	531201   Click image for larger version
ID:	531209   Click image for larger version
post #8 of 33 (permalink) Old Mar 7th, 18, 5:11 PM Thread Starter
I have the car almost completely disassembled. All the interior is out so no wiring, dash, heater box, and I pressure washed everything inside and underneath. I even have one side of the "roof rail weatherstripping" channel removed, so I can access those pillar post cover screws...
The windshield is still installed (loose on both sides and the bottom, but still stuck along the top... I can't find my windshield tool, so I ordered a new one last night from Summit... Hopefully I'll get the windshield out in the next few days and then I can better assess the situation...
I also ordered a Blair spot weld cutter and some replacement cutter tips, as well as the AMD panel... I also have a Sherman panel coming from Rock Auto (I was originally planning on just using it to cut out patches)...
I guess I should also consider ordering the trim clip posts, but need to decide on screw-in or riveted...
TC #1366
Sold
Sold
1966_L78 is offline
post #9 of 33 (permalink) Old Mar 8th, 18, 2:14 PM Thread Starter
David,
You wouldn't happen to have pictures of the rear window channel/panel replacement?
I haven't removed the glass, but I am pretty sure its probably similar... just rust down in the channel though, the "exterior" portions are nice... Just thinking ahead...
Thanks..
New panel for the front, along with my windshield "knife tool is supposed to arrive today...
TC #1366
Sold
Sold
1966_L78 is offline
post #10 of 33 (permalink) Old Mar 8th, 18, 3:51 PM
I used a sharp utility knife to cut my windshield out.
David
davewho1 is offline
post #11 of 33 (permalink) Old Mar 8th, 18, 10:46 PM
David
Yeah - I have a bunch of pix. I'll find the time to send you some of the better ones, but here's one that'll get ya going. This is after i removed the original dutchman panel.
(Notice I removed the trunk lid tension rods in order to not put any unwanted stress on this area under the dutchman panel during this process)
Looks like fun, eh?
post #12 of 33 (permalink) Old Mar 8th, 18, 11:02 PM
Looks like fun, eh?
No.
Aren't there around 1.5 gazillion spotwelds there? I need to do this also, if I want to repair it 'right.'
David
davewho1 is offline
post #13 of 33 (permalink) Old Mar 8th, 18, 11:13 PM
i just replaced this on my 66.man why is yours so shiny??i needed to do the package tray too as in my younger days put some jensen triax II's in there and hacked the crap outof it.i see you have the wheelhouses out.BUT if you do not mess with the wheelhouses the welds on the bottom of the trunk hinge brackets on the wheel houses will hold the brackets and torsion bars right where they need to be.you don't have to relieve tension on the torsion bars.i just left mine there and cut that dutchman panel til i could get to the spot welds on the upper mounting points where the hinge brackets attach on the bottom side of the panel.this works good as the package tray will rest on the hinge brackets so you can put the 2 pieces together.also there was a thin layer of insulation sandwiched between the 2 panels.when i got my 2 panels apart it was full of rust.and i think once it started leaking that the insulation soaked up water and never dried out,so i put some thick filter media like furnace filters,this should breathe and drain if it ever should get wet again.if you don't it will have a tinny sound to it.also check the outer package tray extensions for rust .i had to replace one of mine.
davewho1 likes this.
post #14 of 33 (permalink) Old Mar 9th, 18, 8:21 AM
Originally Posted by davewho1 View Post
No.
I've done this numerous times on various cars and recently on a 66 Chevelle. CHL panel for the Chevelle was a joke. I used an AMD panel and it fit very well, and only needed minor mods to achieve show quality fit of the lower window molding. Use panel adhesive in the trunk gutter and weld the rest. I've never had to remove the torsion rods. I also added drain tubes in the window corners.
Raven1 is offline
post #15 of 33 (permalink) Old Mar 9th, 18, 8:46 AM
the worst part is the welds under the sail panels.actually it ain't the worst part,the worst part is trying to weld up under there.
you need to cut it just like the pic,get a grinder with a cutoff disc and cut right next to the seam.if you count there is about 16 spot welds on the back and about the same on the front.the sides under the sail panels have about 12 each and they are pretty close together.also the corners under the glass and back by the trunk lid are brazed.i just ground it all out and welded em.i also used amd package tray and trunk filler as they call it.and when i welded mine on,when i got to the trunk gutter i could not get my tip down in there far enough so i had to reverse the polarity of my welder,remove the shroud on the tip and use flux core wire.
This Thread is more than 849 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
