Chevelle Tech - View Single Post - Need 427 build advice
post #11 of (permalink) Old Mar 26th, 20, 8:13 AM
pbcbob
Re: Need 427 build advice
a 427-390hp L36 engine back in the day had 10.25 to 1 compression, a 214/218 @ .050 with .461"/.480" lift with a quadrajet, a modern intake and carb should get you close to the hp lost by lower compression so you need 35hp with a cam change assuming no porting on your heads, use one of those online cam calculators such as the one Compcams has
pbcbob is offline
