Chevelle Tech - View Single Post - How best to re-finish 66 Trunk
post #1 of (permalink) Old Mar 21st, 20, 8:46 PM Thread Starter
Jim_66SS
Hi guys. Trying how to best proceed with refinishing my trunk. I am in the process of replacing all the rust in the lower part of the trunk. A previous owner sprayed some junk in the lower part of the trunk pan. The sprayed that with I think something like undercoat. And then sprayed the whole trunk with some junk, maybe a gray spatter product. I believe this was done in 1995.
I partially sanded the upper front of the trunk pan and the junk will come off revealing the original spatter paint. The wheel-houses and the quarters and the tail panel is also sprayed with the gray junk.
Am I stuck with sanding the whole gray junk? Almost impossible to get all the gray stuff off.
Wondering what to use that will stick to the gray stuff and if original type spatter will stick to it or if I will have to use that water soluble GM spatter paint and then a clear
Jim_66SS is offline
