Chevelle Tech - View Single Post - Rocker geometry...my turn
post #9 of (permalink) Old Mar 20th, 20, 10:13 AM Thread Starter
MarkP
Mark
Re: Rocker geometry...my turn
Originally Posted by 69-CHVL View Post
Using a solid lifter?
No Vince, .904 diameter 5470 Morel hydraulics, which are about.100 taller than the ones I had in there. Was using Morel hydraulic 4603 lifter before they got gouged up. The checking springs will collapse the lifters, so doing sweeps for length isn't really reliable. That's why measuring pushrods using Scott's 90 degree method does make sense to me.
I rolled the engine over until I was at half lift on the valve. The lifter collapsing doesn't matter at this point because I just wanted to see where the lifter roller tip was on the valve at half lift. The rocker is at 90 degrees at half lift.
What rockers are on it now ? Just curious.
Bill, these are Scorpion 1014 1.7 BBC rockers. The original set of silver 1014 rockers had grit in them from the two engine failures that I had, so I sent them back to Scorpion and they replaced them for free.
The Scorpion person that I talked to said that they changed the geometry somewhat from the older silver ones that I did have. My poly lock set screw sits about .200" in the in the hole, so I was concerned. The rockers are sitting on the threads of the stud, so I got the shorter adjustment threaded ARP 235-7205 to replace the 235-7202 that are on it now.
Mike Lewis had a procedure to check the sweep by hand using the piston as a stop for the valve. I have to go look that up before I order push rods. I have to get the roller tip where it needs to be before I order push rods.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
