Chevelle Tech - View Single Post - Turn Signal Light Issue and Horn/Horn Relay
post #10 of (permalink) Old Feb 24th, 20, 1:39 PM Thread Starter
oman
Re: Turn Signal Light Issue
For Al and Dan
Thank you both for the advice. Lights they are a-flashing again. Issue was the connection under the column. Put a little "electrical connection cleaner"/ spray on it and POOF all is well. I certainly did not want to dig around under there looking for a bad connection, broken wire and you guys had the info that was needed when it was needed.
This worked out just the way this board was intended to work...the exchange of classic Chevelle information. If only there was a way to get the G-damn politics off the board. Oh well.
Thanks again to both of you.
Oman
oman is offline
