Chevelle Tech - View Single Post - Mad Electrical Part 2
post #5 of (permalink) Old Feb 10th, 20, 5:44 PM Thread Starter
blm
Re: Mad Electrical Part 2
Thanks for the idea guys. Maybe this is same thing. Going to make a bracket/ flat piece of aluminum that is held to the rear of the washer jug bracket via the washer bracket screws. Going to size it about the same as jug bracket frame and paint it black. So in other words if the washer bracket and jug were mounted to the fender and one removed the jug they would see a flat piece of aluminum and when the jug is in place it would be difficult to see the added aluminum. Calculated the added aluminum will be big enough to hold two relays and a terminal block. They will be mounted facing outboard.
Then I came up with a good spot for the remote (Ford) solenoid. Going to mount under the battery tray and on the inner fender. That way the positive battery cable with follow its natural route till it goes out of sight and the solenoid wont be seen.
Just need to find a spot for the primary terminal block. It needs to be on the firewall or somewhere near by. Thinking possibly behind the brake booster???
blm is offline
