Chevelle Tech - View Single Post - Boosted Beaumont Build
post #111 of (permalink) Old Jan 29th, 20, 12:14 AM Thread Starter
GoFast Beaumont
Well that turned out pretty decent, dual fuel pump on a stick! So this assembly is for the B-Body gas tank swap I did sometime ago. The test fit was a success into the small 3” opening. Now to build the hanger assembly.
Just as a side note B-Body gas tank mod was one of the better things I did to the car. Holds 23-24gal fuel, great for range driving. It is extremely well baffled in the inside. Made of HDPE plastic, very light for it size, probably lighter than aluminum. In tank pump(s) is always quieter than anything else possible. Even though I am efi now I did run a carb with the Aeromotive 340. Return system plumbed in already and proper roll over vent. And with the ability to run 2 and stage them on makes this a perfect fit.
ID:	614890   Click image for larger version
ID:	614892   Click image for larger version
ID:	614894   Click image for larger version
1968 Beaumont
540 BBC + 15psi Boost via Single Garrett GTX
Stock looking, and fairly stock sounding
HP and ET not determined yet!
Boosted Beaumont Build:
GoFast Beaumont is offline
