In my 66 convertible I currently have CS6041 springs installed. Rated at 500lbs and cut one coil they are a little bit teeth jarring. I am re-doing the front suspension and tossing my b-body spindles and wondering what springs I should use. It has a 455 block which is about 650lbs I think, no A/C.
Any idea what I should use for something that can take corners, but not be a boat? 500lbs+ feels a a bit too much.
I am using an 8.75 tall spindle and aftermarket controls arms. Its something I drive in summer and like to take corners, but I am not doing any racetracks.
Running Moog 6200 on my 64 with aftermarket control arms and love the ride. It's a really comfortable ride. I'm also running a Hellwig solid 1 5/16" sway bar which keeps the car flat as a pancake through the curves, absolutely love the bar until I got to go over railroad tracks, then you get thrown around like a rag doll.
I too am deep into the process of selecting new front springs and while the weight of the engine plays into the equation I believe you need to know how much the front of the car weighs to select a spring by spring rating.
The front end of my 66 weighs 1,760 lbs. I subtracted the weight of the tires, wheels, spindles, brakes, lower control arms and come up with a front end unsprung weight of approx 1,545 lbs.
I currently have Hotchkis 512 lb/in springs and it WAY to stiff. They are 14.812” tall loose and 11.811” tall installed (1545/5.12=3.01” lower)
I want a spring with an 11.75-12” installed height because I like the stance of my car now but I want a softer spring.
The stock 66 front spring rate for a small block, no AC, 2 door hardtop was rated 250 lbs/in.
512 is to stiff and 250 is to soft so I’m thinking something in the 300-400 lbs/in range.
So far my choice looks to be Moog 5246. They are rated 298lbs/in and are 17.3 tall loose. So at 1,545 lbs it should sit at 12.12” tall installed. I’ll take an 1/8” spacer out of my lower control arm spring seat which should lower the front approx 1/4” (1/8x1.82=.2275”)
I’m still looking at other options too but I DONT want to do this again.
I am using an 8.75 tall spindle and aftermarket controls arms. Its something I drive in summer and like to take corners, but I am not doing any racetracks. Any suggestions? TIA!
Thanks David!
So, for people using the CS5244, are you guys happy with the ride? I like firm but not compress my spine every time I hit a small pot hole.
Thanks again.
The installed heights shown in the chart in post 2 are correct for the load capacity weight shown. If you have more or less front end weight, your results will be different.
Related Threads
Team Chevelle
5.1M posts
115.6K members
Since 1998
