Chevelle Tech - View Single Post - Boosted Beaumont Build
post #106 of (permalink) Old Jan 8th, 20, 12:41 AM Thread Starter
GoFast Beaumont
So got a slipper clutch valve installed. This is from clutch tamer, it is the hydraulic version. I went against the grain of the instructions on this one and didn’t install a 2nd Stage bypass valve. What that means is the slipper system will be active throughout all gear changes. With that said I modified the master cylinder with the lightest return spring as possible, relying on the pressure plate to push the pedal back. Hopefully this will not allow a hydraulic pump up of the clutch system.
The reasoning for this is so it will maintain rpm through the shift points better. Looking over my data logs the rpm was all over the place between shifts. Mount location is just below the steering column. Out of the away and from heat sources. Hopefully this works out well for me, I don’t expect to have to “slip” the clutch much given the nature of the build.
ID:	612960   Click image for larger version
ID:	612962   Click image for larger version
1968 Beaumont
502 big block
HP and ET not determined yet!
GoFast Beaumont is offline
