Chevelle Tech - View Single Post - What's the go to rear suspension?
post #9 of (permalink) Old Oct 6th, 19, 8:12 PM
Kirk's67SS
Greg.
Re: What's the go to rear suspension?
all UMI Perf Suspension parts on my 67
here is what my Street Car has for Suspension / Tires etc.
FRONT
- UMI Perf 64-72 GM A-Body Tubular Upper & Lower Front A-Arm Kit # 403133
- Moroso Trick Springs with a 1” Rubber Spacer under them and Comp Eng 3 Way Shocks set at 80/20
- NO Sway Bar
- UMI Perf 64-72 GM A-Body Solid Tie Rod Adjusters # 2103
REAR
- UMI Perf 64-67 GM A Body Rear Lower Boxed / Adj Upper Control Arms # 402126
- UMI Perf 64-72 GM A Body Solid Rear Sway Bar that attaches to the Lower Control Arms
- Rear Frame Cross Brackets
- Moog Stock Replacement Coil Springs with Air Bags in them
- Comp Eng 3 Way Shocks set at 50/50
TIRES & WHEELS
FRONT
Cooper Star Fire SF P205/70R/15 on JEGs Sport Stars # 66062 1 piece Alum 15”x 7” BS 4”
30 PSI on the Street and 35 PSI at the Track
REAR
M/T ET Street S/S # 3454 295/55/15 on JEGs Sport Stars # 66086 1 piece Alum 15”x 10” BS 5.5”
30 PSI on the Street and 16 to 20 PSI at the Track
See my sig for how the old girl perfs at the Track with the Old School Springs/Shocks
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
