Chevelle Tech - View Single Post - Air bleeds
Thread: Air bleeds
post #7 of (permalink) Old Oct 3rd, 19, 11:02 PM
Tommy the Cat
Re: Air bleeds
I didn't realize you were talking about a Dominator. Those squirters are actually above the bleeds so in theory it could happen. Like I said earlier, make sure the weight is under the nozzles and make sure the gaskets are in good shape. It would be unusual to pull fuel out of there. Could it be running down from the vents? What sort of air cleaner do you run?
70 Camino...Roller
Tommy the Cat is offline
