Chevelle Tech - View Single Post - Switching to synthetic oil
post #14 of (permalink) Old Sep 11th, 19, 6:51 PM
540 Olds
Re: Switching to synthetic oil
No problems going to synthetic; most of the stuff on here and online are outdated wive's tales... If your engine is not burning oil, I'd go with a good synthetic and change it every 10K or more, or not "change it" at all...I can see some of you spitting up the drinks now...
I bought an 05 Suburban; 5.3 liter, 125K miles...Ran it for a while to make sure it didn't use, burn or leak; went through a qt every 5k miles which is nothing. I switched to synthetic and I change filter every 5-7K, add the oil to make up for the burned qt and the filter, and DO NOT drain the pan.....no problems at 165K. This is a highway driver that gets HOT every time it's driven so not a bunch of condensation/water built up on 3 mile drives...
I'm still amazed so many are using 50 year outdated ideas about oil quality and change intervals...Even the Walmart "Super Tech" synthetic is very good stuff...
540 Olds is offline
