Chevelle Tech - View Single Post - L36 re-cam results.....
post #15 of (permalink) Old Aug 27th, 19, 10:24 PM
CPMotorworks
Pete
Re: L36 re-cam results.....
Originally Posted by RickyHill View Post
What am I missing here? There must be something pretty major as i did a search here before i had John do my 427 and i recall the same 427 l36 from 2015 making 469 horsepower and 510 torque on pump 91. This was just a cam change to hydraulic roller as well with just a catalog howards cam and same i think the same lifters. Reason i did the search was i was second guessing John on getting over 500 horsepower with the l36 heads and solid flat tappit cam. So is it the carburetor that is loosing 40 horses and 50 torque.
RH
I can answer part of your question...
You are referring to this thread..
https://www.chevelles.com/forums/13-...90hp-dyno.html
The 469HP/510lbs was the observed power... on a -5F day with outside air coming in.
It was a negative correction that day, to 438HP/499lbs for the J607 correction of 60F, 29.92 Baro, 0% humidity.
All the photos seem to be missing in that thread, so it may be hard to follow.
CP Motorworks,Inc
Custom Performance Engines &
Cylinder Head Fixtures for Vertical Mills and Surfacing Machines
1971 Chevelle 406- Mine
1970 Chevelle 496- 10.2:1, 781 ovals, 3.31, 275/60 DR 3800lbs, [email protected] on 91 octane - Hers
CPMotorworks is offline
