Chevelle Tech - View Single Post - Cam timing big block 540
post #12 of (permalink) Old Aug 24th, 19, 10:33 PM
540Hotrod
JIM
Re: Cam timing big block 540
Originally Posted by berserker View Post
I have a long time project. A 540 big block that i will be installing the cam and timing set on soon. So the cam card calls for a 108 icl, no advance. do you guys think that sounds right or should i install it advanced? I have a stock 572 timing set so I would have to use a ofset key.
Engine specs are. 4.5x4.25 540, brodix bb2 xtra heads, super victor intake, 10.75:1 comp, cam is 260/268 108 lsa, 714/714.
How much would I gain or loose with say four degree advance?
The very first iteration of my 540 was very similar. 10.5 compression, out of the box Brodix 2Xtra's...but I had an older Team G intake (short one) with a 1050 Dominator...no spacer. My cam was a 262/273 on a 112 LSA. .731 lift. It made [email protected] 6400 or so. The Super Victor should help 20+ HP at least.
Those heads respond very well to some port work. The same basic engine made 870'[email protected] after becoming a 555" with another point of compression, ported heads, SV and a 268/272" cam. Still dyno'ing and racing on 93 octane pump gas.
All of this was with a belt driven water pump and no vacuum pump.
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
