Chevelle Tech - View Single Post - Block Deck Smoothness
post #7 of (permalink) Old Aug 23rd, 19, 7:45 PM
BillK
Mr Bill
Re: Block Deck Smoothness
Originally Posted by Bill70 View Post
Thank you all for your responses. Hopefully you can answer another question. Is there any chance I can rectify this at home with a sanding board?
Probably not. If you are going to use anything use a 2"x6" knife sharpening stone with WD40 A "sanding board" is simply not flat enough to give a flat surface.
To be honest with you it will probably be fine the way it is even though it is not ideal. I have a Fel Pro surface comparator floating around somewhere. I will see if I can find it and take a picture of the lower Ra areas so you can see them.
A lot of it is also going to depend on what the intended application of the engine will be. If it is a stock engine it will probably be fine. Race engine with a ProCharger .... I would have it surfaced correctly.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
